Old 07-31-2007, 10:36 PM   #1
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
How many seconds do you think such a mod will help acceleration ?
Currently, I'm on 195/50R 16s, 16x7" rims. Probably 11 pounds or so a rim. I'm also on stock pulleys.
I have little to no intention of compromising reliability, so I will not go forced induction, whatsoever. WHat I'm keen in is, to increase efficiency of power delivery to increase acceleration.
SO...
What if I went, 195/55R15, 15"x6.5JJ 9lb rims. This will reduce rotating mass by over 6 lbs inclusive of a lighter tyre. I will also change the pulleys to one of those lightweight aluminum variants. I will change my engine oil to 0w-40w Mobil 1. And if need be, thicken my autotransmission oil, and remove the 20kg or so sitting in my boot.
Do you think I will be able to reduce my acceleration from the current 11. something seconds to a sub ten ?
I have no intention of a cold air intake, because frankly, I've got that route before and I think in an automatic, it sucks. A big torque hole.
nurburgring is offline   Reply With Quote
30 seconds door panel removal (Liftback) W.A.S.P DIY / Maintenance / Service 62 10-17-2018 03:25 AM
get better acceleration ? kty75 Performance Modifications 63 05-05-2009 02:06 PM
stick vs. auto acceleration abcando General Yaris / Vitz Discussion 36 04-08-2009 08:06 AM
[Insert Mod Here] Installed + No Pics Rule bigsky2 Suggestions - Feedback - Questions 6 02-14-2007 01:21 AM
Toyota Yaris S Mod jamal1984 Performance Modifications 10 01-07-2007 02:48 PM
