Old 08-11-2007, 08:39 PM   #1
CompanyXPaladin
Drives: 08 Yaris 5-speed
Why Industries
Has anyone used Why Industries for anything? I am looking specifically at the Yaris Turbo Kit they have available. Anything to report about these guys? Is this another ZPI in the making? It looks like a fairly complete kit for a pretty reasonable price. What do you guys think?
http://www.whyindustries.com/store/p...products_id=51
CompanyXPaladin is offline   Reply With Quote
Old 08-11-2007, 09:08 PM   #2
RShatchback
Drives: 07 yaris liftback
You should really call or email them if you interested in the kit and then post your findings here
I dont see anything on that list about engine management/tuning so I wonder what they are using - cause that usually seems to be the trickiest part on this car...
I'm still waiting for a reputable company, these private kits are fine and I'm glad someone is doing something - but look what happened with zpi, so I dont know...either way, check it out.
Car forums are kinda like the public library - somepeople are just checking stuff out, and plenty of other people are just telling stories...
RShatchback is offline   Reply With Quote
Old 08-11-2007, 09:09 PM   #3
ChinoCharles
Drives: LB
No management... tack at least $500 onto that price for an e-manage and some dyno time.
Old 08-12-2007, 12:29 AM   #4
I thought our ECU compensated/disabled attempts with eManage?
Old 08-12-2007, 12:32 AM   #5
1. I don't like that they only give a P.O. Box.
2. I don't see any dynos or other verification of power gains.
3. I don't like internal wastegates.
With that said, it's worthy of further investigation. Who's making the call?
Old 08-12-2007, 12:58 AM   #6
joey1320
joey1320's Avatar
Drives: Yaris LB
i feel the same way. i think for a "company" to come out and advertise for a specific turbo kit they should have some kind of dyno sheets/videos. is pretty simple to get a video of a dyno run and use it as a means to back up your claims nowadays...
why don't you like internal wastegates? they do a pretty good job on pretty much every oem turbo car...
joey1320 is offline   Reply With Quote
Old 08-12-2007, 01:07 AM   #7
joey1320
joey1320's Avatar
Drives: Yaris LB
it does. the only way i know is to remove the front o2 sensor which will throw a cel but then the ecu won't be able to reset the adaptation values.
T&A said he used some kind of special unit for his turbo matrix but i'm not sure what it was called and if it will work on our cars. it supposedly allows you to boost the car without having to remove the front o2.
Old 08-12-2007, 12:01 PM   #8
ok, about wastegates. I'd like to be able to change out the whole wastegate, or just the spring in the wastegate, etc. as needed. Sometimes these changes become desirable as you make other changes/upgrades to a turbo system. This has definitely been true on my tC project.
If I turbo my Yaris, I will be tinkering for a while, I'm willing to bet on that! I haven't seen a turbo kit yet that doesn't require further tuning/maintenance/monkeying to work properly.
Old 08-12-2007, 03:24 PM   #9
redduck
Drives: Yaris
looks a little too mom and pop for me
redduck is offline   Reply With Quote
Old 08-13-2007, 12:23 AM   #10
YarisGuy
Drives: 2006 Yaris
You would think a company building turbo kits would be able to take better pictures of the kits installed and use better page setup. Look at the font
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 08-22-2007, 12:57 PM   #11
lifthard1
Drives: Black LB
that just looks shady to me.Like said above no management nor larger injectors.And from my past exp. with new toyo motors the design of the mani you will be blowing gaskets all day long.Just ask T&A He and I have delt with the toyo 2zz motors and the Turbo woes
lifthard1 is offline   Reply With Quote
Old 08-22-2007, 01:50 PM   #12
Well... has anyone picked up a phone and called them? Easy to conjecture from here, but let's see what they have to say?
Old 08-27-2007, 10:52 PM   #13
dude, you need to check out this thread.
http://www.yarisworld.com/forums/showthread.php?t=8258
I talked to Todd myself, and not all of what you said is correct. He's very nice, and I think the product looks great, but read the other thread. 1. He never installed it in a Yaris and 2. he's selling it as is, not with injectors and management.
I have a turbo tC also, by the way.
Old 08-28-2007, 01:29 AM   #14
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
he's only got one post... i wouldn't trust it.
reznunt is offline   Reply With Quote
Old 08-28-2007, 09:58 AM   #15
sciontc,
The main issue with the Yaris at this point is management. It does not have the same ECU as the Scion, so piggybacks like eManage don't work. Our ECU is "smart" and compensates for changes the piggyback tries to impose on it.
No one has an acceptable solution yet, including Todd, so we're waiting for someone to crack the ECU and/or come up with something less expensive than a standalone. After that, you'll see a LOT of turboed Yaris.
Like I said -- Todd seems to be a professional guy and his hardware looks great, but that is not a complete kit and it hasn't been installed in a Yaris yet.
(Todd did a motor swap on his Yaris instead, by the way.)
Old 08-28-2007, 03:58 PM   #16
CompanyXPaladin
Has anyone thought about running a MegaSquirt or a MegaSquirt II in a turbo Yaris?
Old 08-28-2007, 10:47 PM   #17
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
no time no money...
yes, but i have no time, money, or expertise in engine managment ... so i figured my daily driver is a poor place to start...
fu_im_from_texas is offline   Reply With Quote
Old 08-29-2007, 12:43 AM   #18
CompanyXPaladin
Yeah, I hear you on that count. I might swap my FC Commander in my other car out for one just to play with it and see what I can do...
