![]() ![]() Drives: 2009 Toyota Yaris Sedan S Join Date: Aug 2009
I recently purchases the Eclipse AVN4430 double din head unit for my Yaris and was wondering if anyone knew how to do the video bypass while driving? I read that the other Eclipse AVN head units only require you to ground the brake wire. Does anyone know if this is true? Thanks.
From what I read, it looks like the AVN4430 just needs the parking brake wire grounded. It doesn't seem to need the toggling of the signal like some other manufacturer's units do.
Thanks. I'll try that hopefully it works.
Drives: Yaris RS 2010 Join Date: Apr 2010
Hello rexseesyou, i'm planning on installing an AVN4430 on my Yaris 2010. Do you know if an adaptor is required, or the Double Din fits good ?
Thanks |
| Tags |
| bypass, eclipse, install, stereo, video |
