Old 03-16-2010, 03:24 AM   #1
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
ok, so where the hell do I ground my amp??
I am in the middle of my amp install and I have ran my power cable, but I cant see any convenient place to to screw the ground wire to the chassis. The 4 bolts that hold on the plastic panels are screwed into rubber and the bolts that hold the seats down are some weird bolt i don't have a tool for. Do i make my own screw hole in a random place and screw it down? how do i avoid damaging something important?
Old 03-16-2010, 04:30 AM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
well, generally you want the best possible ground which means the lowest possible resistance. However, if you want the easiest possible ground.... try the seat belt bolt. You'll need a big ring connector for those tho.
Old 03-16-2010, 10:21 AM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Make sure when you do find a convenient location to scrape the paint off, you want bare metal to make good contact, and a good ground. I was surprised at how the battery was grounded to a painted area, Nice engineering.
While you're there working on that wire, i'd reground the battery and scrape that paint off of where the battery grounds to the chassis, It's a quick and easy fix and will deff help with the lights not dimming.
And what you'd probably be looking for to connect to that seat belt bolt is a copper ring terminal, You can either solder it onto the wire or take a hammer to it, them things are pretty tough so if you want to crimp it make sure your wire crimper has long handles. I picked some up at my local Ace Hardware for around a buck.
Old 03-16-2010, 11:04 AM   #4
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
I had my amp ground in the trunk
Originally Posted by sw07gt
Old 03-16-2010, 11:46 AM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I always just put it on the cement and gave it 2-3 whacks from a hammer. Course... I was also using 1/0 crimp connectors.
Old 03-16-2010, 12:40 PM   #6
_S7V7N_
_S7V7N_'s Avatar
Same here with beating them on the cement, them things are bullet proof, then just wrap the back part with some electrical tape and presto you're good to go . ( I like to put a lighter to the electrical tape after wrapping just so it'll stick better. )
Note: Make sure to note if you need any ring terminals on the power wire and get them on before you install it that way you aren't done and ready to connect everything and then you're like damn, How the hell am i going to crimp these things.
Old 03-16-2010, 02:55 PM   #7
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
I just man connectors on wires... with my fingers... :P
After the bleeding stops I break down and get channel locks lol
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Slick is offline   Reply With Quote
Old 03-16-2010, 09:36 PM   #8
CtrlAltDefeat
I ♥ Yaris
Ok... I searched everywhere, a hardware store, 3 car part stores, a stereo install place, and best buy, and I cannot find a 4 gauge loop terminal that will fit the bolt in my seat belt mount... I'm about to solder a few loops of bare copper wire onto the end of the ground cable...
Old 03-16-2010, 09:50 PM   #9
Palmer812
Drives: 2010 Meteorite Metallic LB
Try a welding supply store. I have bought some copper ones there before that were large enough to drill out the hole big enough for a seat bolt.
Palmer812 is offline   Reply With Quote
Old 03-17-2010, 12:06 AM   #10
_S7V7N_
_S7V7N_'s Avatar
I had trouble as well, smaller places like Ace if not a locally owned hardware shop will have them in the welding section. Try finding 0 or 4 gauge spades, that's even more fun.
How to ground my Amp on Yaris Hatchback charleschia1986 In Car Entertainment + Electronics (audio / video / alarm) 35 11-20-2009 03:13 PM
Amp And Cable Kit Question Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 13 01-28-2009 06:59 PM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
