Old 11-02-2008, 03:21 PM   #1
captainm27
Drives: 2008 Sedan A/T Silver
Tire Rotation
I have a question about rotating tires. Is that something that the dealer has to do, because of the tire pressure sensor? Or can anyone do it? Is the sensor built-in to the tire?
captainm27 is offline   Reply With Quote
Old 11-02-2008, 04:27 PM   #2
nemelek
DWEED
nemelek's Avatar
Any one can do it.
Old 11-03-2008, 12:21 AM   #3
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
Instructions are in the owners manual.
Reddog99 is offline   Reply With Quote
Old 11-03-2008, 12:31 AM   #4
b_hickman11
Drives: 08 Sedan
You dont have to do anything different from a car without the sensors.
b_hickman11 is offline   Reply With Quote
Old 11-03-2008, 12:56 AM   #5
YarisSedan
Drives: 08 Yaris Sedan
Our tires have 160 treadwear. Most decent tires are atleast 400 treadwear.
What does that tell you. Your tires will wear out within a year or two no matter how many times you rotate them. Just save the 20 bucks or wahtever you spend on tire rotations every few months and use that to buy some good times when the time comes.
Old 11-03-2008, 11:38 AM   #6
b_hickman11
Drives: 08 Sedan
Or you could save $20 and do it yourself....takes about 10 minutes.
Old 11-03-2008, 11:39 AM   #7
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Or get better tires and rotate THOSE yourself
Its a Chao!!!
Old 11-03-2008, 11:42 AM   #8
*MAD DOG*
*MAD DOG*'s Avatar
Yeah, if you have a F1 pit crew with you (yes, sarcasm). If you don't have a hydrolic jack and or an air wrench it would take you way more than 10 mins to rotate an entire set of wheels by yourself.
Old 11-03-2008, 01:17 PM   #9
b_hickman11
Drives: 08 Sedan
I did mine last weekend in 10 mintutes using a 2-ton floor jack, 2 jack stands and a 4-way tire wrench....guess you just need some practice
Old 11-03-2008, 02:36 PM   #10
captainm27
Oh ok, I was just curious, how does the car detected the tire pressure? When you put the tire in, does it connect to some kind of sensor?
Old 11-03-2008, 02:53 PM   #11
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Don't know the exact methods they use, but the way the system figures out if something is wrong is it compares all the tires to each other. If one is off by more than I would guess 5 psi, it'll light up. This particular system can't tell you if say, your right front is low.
No connection at all. All of it is in the valve stem.
...I rotate every 10k...or 2 oil changes.
Old 11-03-2008, 11:01 PM   #12
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
The sensors are at the end of your valve steam, found that out the hard way
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 11-04-2008, 12:00 AM   #13
b_hickman11
Drives: 08 Sedan
The sensors are wireless and they run off of an internal battery. They can tell you if one tire is low, but the Yaris is not advanced enough to show you which tire it is. If one or more tires are low, you will see a " ! " on the dash. More expensive cars will tell you which tire it is or you can look at the psi of each individual tire at anytime. They are located on the inside of the tire, mounted on the rim. They will not detect a sudden decrease in psi such as if you ran over a nail or had a tire going down fast.
Old 11-04-2008, 02:01 PM   #14
Benggolf2
Benggolf2's Avatar
I've got 205/40R-17 Bridgestone Potenza G 019 Grid XL on the Yaris. They have a Uniform Tire Quality Grade (UTQG) rating of 460AA.
To read more about UTQG, click on the link below.
http://www.tirerack.com/tires/tirete....jsp?techid=48
Try not to compromise on tires as they are the only thing between your car and the road!
Benggolf2
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 07:29 AM
Do the tire rotation myself. hans_fh General Yaris / Vitz Discussion 6 06-06-2007 11:01 PM
10 Bucks for Tire Rotation hans_fh General Yaris / Vitz Discussion 11 06-05-2007 11:38 PM
Tire Rotation and Position Change hans_fh General Yaris / Vitz Discussion 26 06-01-2007 07:25 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
