Old 10-25-2008, 06:00 PM   #1
onizuka
Drives: Yaris Blk 5 Drs RS
can't fuel gas
Trying to pump gas this morning, it keeps popping out the pump trigger. My tank is empty, and it keeps clicking at every $1.
At first I was blaming my local gas station, but I tried another one near by, same thing.
Something must be wrong with my gas tank???
onizuka is offline   Reply With Quote
Old 10-25-2008, 11:44 PM   #2
sketch182
sketch182's Avatar
Drives: 2008 Silver Hatchback
Sounds like a blockage in the filler neck. It is causing the pressure switch to shut off. the siphoning guard may have a problem.
sketch182 is offline   Reply With Quote
Old 10-26-2008, 08:35 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
just pull the tip out a little...
i never shove it in all the way in.
Old 10-26-2008, 10:53 PM   #4
Benggolf2
Benggolf2's Avatar
.....and try not to pump gas too fast. Easy on the trigger.
Old 10-27-2008, 12:14 AM   #5
Appalachian Trail 2007
Appalachian Trail 2007's Avatar
Drives: 2008 Yaris LB
sounds like you guys are giving sex advice, "pull the tip out" and "don't pump too fast"
3,441,567,453 posts BH (Before Hack)
Appalachian Trail 2007 is offline   Reply With Quote
Old 10-27-2008, 12:29 AM   #6
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
are u putting it in at an angle? if u dont put it in right, it wont want to feed the car..
and ur right.. it can double as sex advice.. we all know you men have trouble finding the hole.. hell, you cant even aim right when u pee!
Old 10-27-2008, 12:58 AM   #7
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
This has happened to me once before on my Yaris.
Have Toyota check to see if all your fuses are intact.
I had taken my car to Fry's Electronics to install an aftermarket headunit. Little did I know that they had accidentally loosened a fuse or connection and this led to my fuel readings to be inaccurate. When I pumped gas, it kept clicking because it was really full. Toyota checked it out and sure enough, a fuse was unplugged.
Sponsored by: Micro Image
http://microimageonline.com
Old 10-27-2008, 02:23 AM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Where's the fun in that?
Old 10-27-2008, 02:26 AM   #9
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Why don't you show me some time
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 10-27-2008, 02:30 AM   #10
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
lol oh yes, absolutely! i'd love to
Old 10-27-2008, 10:24 AM   #11
IllusionX
i don't know, but if you guys read about female ejaculation...
According to female experience (found on google)... some says it's not going all in but rather having the tip massage the spot and then around the clit.
why did pumping gas lean toward sexual pleasure??
Old 10-27-2008, 05:27 PM   #12
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
meh if we really needed to get off during sex, we'd just use a vibrator and let u sleep!
Old 10-27-2008, 05:47 PM   #13
zzzzZZZZzzzzz excellent
Old 10-27-2008, 06:24 PM   #14
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Spanking the clit works better than a vibrator ..................
Much more explosive
Old 10-27-2008, 06:30 PM   #15
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
hmmm nah, not really
Old 10-27-2008, 08:29 PM   #16
sketch182
sketch182's Avatar
And I thought that we were taking about a gasoline fill problem. It always gets down to the basics.
Old 10-27-2008, 08:31 PM   #17
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
indeed... its all the same in theory.. u do it the same frequency...
Old 10-27-2008, 11:51 PM   #18
ECHOKnight2000
Small Car Lover
Drives: A Super Car
Oh, oh, oh, must not, oooooooooooooooooohhhhhhhhhhh....too late
Oh yes gasoline, that's the common fuel I was thinking of
Sedan better gas mileage than LB? 5 month gas chart included flint_mica_manual General Yaris / Vitz Discussion 24 03-09-2009 09:24 AM
branded (chevron) or generic (costco) gas?? static808 DIY / Maintenance / Service 55 11-28-2008 06:14 PM
Huge Gas Milage Reduction from installation of intake YarisSedan Fuel Economy Forum 14 10-22-2008 10:09 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 04:20 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
