Old 05-09-2010, 10:09 PM   #1
yaris_trd
Drives: toyota yaris hb
Question who know about
hey guys I ask if they know or have used these spaks plug know if they are good
http://cgi.ebay.com/ebaymotors/PULST...Q5fAccessories
yaris_trd is offline   Reply With Quote
Old 05-09-2010, 10:12 PM   #2
90tsi
90tsi's Avatar
Drives: 09 yaris
there suppost to be outstanding from what i read and seen on a motortrend review but i thought someone tried them and began having coil issues.... dont qoute me tho. maybe someone can correct me.
90tsi is offline   Reply With Quote
Old 05-09-2010, 10:15 PM   #3
90tsi
90tsi's Avatar
Drives: 09 yaris
http://www.yarisworld.com/forums/sho...ht=pulse+plugs
answers here.....
Old 05-09-2010, 10:46 PM   #4
yaris_trd
well I ask this because myyaris has prius pistons and spark plug damage to me then told me about these spark plugs but do not know whether to buy or if you know of anything I can do about it ?????
Old 05-09-2010, 10:52 PM   #5
90tsi
90tsi's Avatar
Drives: 09 yaris
are you still running the oem coils? thats whats getting burned up. your compression ratio is not really gonna have that effect.
Old 05-10-2010, 03:20 PM   #6
yaris_trd
okay then what would be a good recommendation I can do with that or do other modification to this ???
Old 05-11-2010, 08:25 PM   #7
yaris_trd
no one who can help me with this problem I have or I may say to do to fix it please help me
Old 05-12-2010, 11:05 AM   #8
severous01
if you have plug damage, you may have piston damage. is the plug hitting the piston? if so you'll need a shorter plug.
you'll have to do your own research there, find out how much shorter you need, open a few boxes and compare thread sizes and sealing styles...wether it uses a crush washer or if it's got an angled head or whatever it uses.
lot of work goes into replacing oem parts with non=oem. not saying toyota vs toyota, but in ur place where you use non yaris pistons. had a buddy put a lt1 crank/pistons and head on his tahoe...his computer wouldnt accept it. he had to run a special program...and i had that program available for my camaro. fixed his problems with a little timing and fuel curves. also reducing his knock sensor sensitivity.
any way, looks like you got some playin around to do. maybe use prius spark plugs too.
Old 05-12-2010, 08:57 PM   #9
yaris_trd
ok man thanks
