Old 04-10-2009, 04:05 AM   #1
chinoken503
Drives: Yaris 07
Question about HID for 07 Yaris
Hi everyone, I am new to yaris world, and I was wondering if I should get Single Beam HIDs for my 07 Yaris? If i do get it and install them, what would happen if try to turn on my high beams? Also I've been looking at some HI/LO HIDs (Not BI-Xenon) and I don't know what to get? Any advice is greatly appreciated.Thanks
chinoken503 is offline   Reply With Quote
Old 04-10-2009, 04:13 AM   #2
Get a single-beam. The hi's on mine are about as useless as using a dirty rag towel to wax my car.
Old 04-10-2009, 04:25 AM   #3
chinoken503
Drives: Yaris 07
What would happen if i get a low beam and i turn on the high beam? Would the HID blow?
Old 04-10-2009, 04:33 AM   #4
There should not be a high beam bulb. So I don't think anything will happen. hehehe. My HID low and halogen Hi has two bulbs. The halogen bulb is right next to the HID bulb, very small, and very useless.
Old 04-10-2009, 04:40 AM   #5
chinoken503
Drives: Yaris 07
So you purchased one of those HI/LO bulbs with an HID low and halogen HI that are fitted right next to each other? So if i get a single beam HID bulb and turn on high beam it should do nothing?
Old 04-10-2009, 05:02 AM   #6
Well, not necessarily, like the comment above, things just might get dark. Our cars shut off the low beams when the high beams are turned on. On my kit, there are two cables, one for the high and one for the low (HID), so if there is no cable for the high, there will not be a place for the power/wattage to go to/diverted to, so, nothing happens, nothing turns on.
Old 04-10-2009, 04:52 AM   #7
AlainMikli
AlainMikli's Avatar
if you using a single beam HID, if you turn on the High Beam, may be everything will turn off.
my friend's has a fits after install hid, the high beam will turn off everything~
but after some wiring he seems to get rid of it, nothing happen when turn on the high beam~
Old 04-10-2009, 04:57 AM   #8
chinoken503
Drives: Yaris 07
So turning on the high beam will turn off the Low beam HIDs when enabled if i only have a single low beam?
Old 04-10-2009, 05:35 PM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
but why don't you just get a bi-xenon? or Hi/Lo HID...
Old 04-10-2009, 05:51 PM   #10
AlainMikli
AlainMikli's Avatar
bi-xenon s super expensive..................
Old 04-10-2009, 07:31 PM   #11
chinoken503
Drives: Yaris 07
bixenons are super expensive, i'm just worried about where the voltage and current will go when i turn on my high beam, i don't really care for high beam i rarely used them.
Old 04-11-2009, 01:21 AM   #12
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Read this bixenons are not that bad and they are proven by many members on here.
http://www.yarisworld.com/forums/showthread.php?t=9610
Old 04-11-2009, 11:29 AM   #13
IllusionX
bi-xenon use no more power than any other HID kits..
it's simply 1 HID bulb with an actuator behind to move it back and forth. Most be-xenon kit sold on ebay have this cover on the bulb, it helps blocking the extra lights that glare.
117$ is not expensive
http://cgi.ebay.ca/8000K-Bi-Xenon-H4...3A1|240%3A1308
Old 04-11-2009, 11:51 AM   #14
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
I have a regular HID kit and works just fine. I just don't have the high beams. The only thing that happens if you turn into high beams on this case is that it won’t be any light at all. Honestly, with HIDs you just DON"T need high beams!
GioBatera
Giobatera is offline   Reply With Quote
HID Question!! MurderCivic Cosmetic Modifications (Exterior/Interior) 4 01-21-2009 03:29 AM
Question on Yaris wheels featherz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-17-2006 10:27 PM
