Old 06-21-2007, 11:26 AM   #1
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
Send a message via MSN to Sway84
HELP! where to buy LED bulb consoles
i lost one of mine trying to DIY the Center Console lighting and now im 2/3 lights out..., lost one console and need help...i left the 3rd cause id probably strike out... im not too good at all with positives or negatives but the middle one when i turned power on it went on then off and never back on... someone help me!
the DIY was only good for so much...lol please help!
Rice on, Rice Off
Ron Cabading
Sway84 is offline   Reply With Quote
Old 06-21-2007, 11:50 AM   #2
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
is it neo wedge led type a or type b? from autolumination.com
Rice on, Rice Off
Ron Cabading
Old 06-21-2007, 02:32 PM   #3
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
it sounds like your putting them in backwards... and if left on to long will cause the LED to burn out...
"Type B Neo - Wedge Instrument Panel Bulbs are 10mm (3/8") diameter x 13mm (1/2") high"
this page http://autolumination.com/74.htm 10th from the bottom
unless i am incorrect in which please correct me
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 06-22-2007, 01:00 AM   #4
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
now vodka are they just housings or housings with the LED on?
Rice on, Rice Off
Ron Cabading
Old 06-22-2007, 09:11 AM   #5
vodkalush
I drive a yarrrris
vodkalush's Avatar
well it depends on what your changing... since you referenced the autolumination.com site i am assuming that you are changing out your temperature controls/fan/shifter light
if your changing your speedo cluster color then thats a completely different story and there are links to the LEDs i used in that thread...
will work for parts
Old 06-28-2007, 03:48 PM   #6
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
are these neo wedge type b bulbs the bulbs for the 3 giant knobs for the climate control? and are they the same as the light in the shifter for the auto trans?
Old 06-28-2007, 04:13 PM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
the auto shifter is a different base
SPONSORED BY
Old 06-28-2007, 04:13 PM   #8
redyaris
Shiny Chromey Coolness
redyaris's Avatar
The neo wedge bulbs come with a base.
When you insert the base of the bulb in the AC controls turn it clockwise to lock it with a pen.
If it doesnt light up immediately take it out and turn it around and try again.
If you leave in an LED that is not illuminating it will pull load from elsewhere and start frying things.
The shifter bulb is the TRI POWER bulb. Its not a wedge base. Its a direct plug in type.
Purchase them from autolumination.com. They are VERY reasonable, you can order direct from their website and shipping is VERY quick.
I redid my entire interior and license plate and not one problem.
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 01:02 PM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 09:30 AM
Exterior LED bulb Replacement & Tint ||)) (o) ||\|| Cosmetic Modifications (Exterior/Interior) 2 04-27-2007 06:45 PM
Festoon (dome light) led bulb fit?? ||)) (o) ||\|| Cosmetic Modifications (Exterior/Interior) 5 03-22-2007 03:22 PM
GROUP BUY...Spiderlite X2,plug n play LED stop lights. eco Cosmetic Modifications (Exterior/Interior) 12 10-07-2006 12:05 PM
