Old 07-23-2006, 02:02 AM   #1
jommani2000
jommani2000's Avatar
Drives: Polar White, 3Dr, power packag
Will 14 inch with 28mm offset fit
I need to know if a 14 inch rim with 28mm offset would fit the front and the rear of the hatchback yaris with stock tires.
Thanks in advance.
jommani2000 is offline   Reply With Quote
Old 07-23-2006, 11:48 AM   #2
johnnyfive
johnnyfive's Avatar
offset has more to do with the width of the rim, than it does with the diamater, so what is the width of the rim you are wanting to use?
johnnyfive is offline   Reply With Quote
Old 07-23-2006, 04:53 PM   #3
jommani2000
6.5 is the width.
Thank you for your assistance.
Old 07-23-2006, 07:55 PM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I can't say for sure, but I don't think so.
From what I was able to gather when researching for mine, you need an offset in the 35-45 range. Staying between 38 and 42 is best.
But don't take my word for it. I didn't order mine until the retailer guaranteed return shipping if they didn't fit.
Old 07-24-2006, 11:13 AM   #5
Duckywitbigfeetz
Drives: 07 Polar White Yaris Hatch-3DR
do you know what the offset of the stock are
kinda easier with a point of refrence
Duckywitbigfeetz is offline   Reply With Quote
Old 07-24-2006, 11:17 AM   #6
Duckywitbigfeetz
im looking to get 17x7 on mine running 205/45 but i need to see if theyll fit first and then what offset might have to go smaller in front at least
Old 07-24-2006, 01:47 PM   #7
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
Originally Posted by jommani2000
6.5 is the width.
It will work but look kind of lame... and make sure the wheels are actually 4x100 bolt pattern, since you perfrectly spelled out a 4x114.3 wheel.
heylookitsjames is offline   Reply With Quote
Old 07-24-2006, 09:50 PM   #8
jommani2000
Yes, it is a 4X100. If it does work and like you've mentioned "it might look kinda lame" what do you mean?
Thanks
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 12:09 PM
The Honda FIT... Leenis24 Off-topic / Other Cars / Everything else Discussions 198 08-09-2006 07:11 PM
Ideal Offset? 15x7 ET42 Wheels TRD_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-18-2006 04:12 AM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
Max offset riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-01-2006 09:57 PM
