Old 10-27-2008, 06:46 AM   #1
Nigal
Nigal's Avatar
Results from 100,000 maintenance
Since my thread got zapped in The Great Crash of '09 I thought I'd post the results from my 100,000 maintenance. Even I was amazed. He did a radiator flush, tire rotation, alignment, checked the brakes and basically anything and everything else. The only thing that was worn and in need of replacing was my windshield wipers. He said the brakes looked good and didn't need changing but he did adjust them a little. I figured the brake pads needed changing at the least.
It's ready for the next 100,000 miles!
Old 10-27-2008, 07:37 AM   #2
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
holy moly damn you drive alot
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-27-2008, 09:27 AM   #3
dacourier
dacourier's Avatar
Drives: Black Sand Lift Back
Do you have any engine mods or no? Air intake header or an exhaust?
Clinging to my guns and religion down here in the south. Come and take them!
dacourier is offline   Reply With Quote
Old 10-28-2008, 06:31 AM   #4
Nigal
Nigal's Avatar
I have a short ram intake and this is the only mod.
Old 10-27-2008, 01:38 PM   #5
SIPNGAS
I LOVE my Yaris!
SIPNGAS's Avatar
Drives: 2007 Polar White LB
Wow! This is GREAT news for the rest of us...
Lisa
aka SIPNGAS
Old 10-27-2008, 01:54 PM   #6
I recall reading this pre 10/18. While it is good to hear your 100,000 mile results, it does need to be noted that the average individual will require atleast 6 to 8 years to achieve this kind of milage.
The wear and tear conditions drastically differ between achieving 100,000 in short order, compared to 'normal' racking up of the miles.
Old 10-27-2008, 02:32 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
I would still change the spark plugs at 100k even if they look like they have a tiny bit of life left. I dont like leaving plugs in for excessive milage as they have a chance of seizing up in the cylinder head.
Old 10-27-2008, 02:42 PM   #8
gid
Drives: '08 Yaris sedan , '08 Liftback
+1 on spark plug change ...
even if they are iridium , you'll get deposits on the tips from additives , motor oil ( blow by past rings ) , etc.. They will wear and gap becomes larger making for pour firing . These conditions will decrease power and mileage . Had them change the iridium sparks in the 2000 Chevy PRIZM ( Corolla ) at around 90,000 miles and there was a noticeable increase in mileage and pickup . They do say 120,000 mile change , but that's stretching it a bit in my opinion .
gid is offline   Reply With Quote
Old 10-28-2008, 06:33 AM   #9
Nigal
Nigal's Avatar
The plugs did get changed. I forgot to add that to the list.
Old 10-27-2008, 06:55 PM   #10
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Look at that Black Yaris, brake pads that lasted over 100,000 miles. Someone knows how to drive...
PetersRedYaris is offline   Reply With Quote
Old 10-27-2008, 07:10 PM   #11
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Nigal......
What had you replaced up until now? Tires? Brakes? etc?
Old 10-28-2008, 06:34 AM   #12
Nigal
Nigal's Avatar
Originally Posted by Bob_VT View Post
Nigal......
Tires and one set of wiper blades. That's it.
Old 10-28-2008, 08:37 AM   #13
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
That's great. I am on a 3000+ mile a month pace and just wanted to check.
Old 10-28-2008, 11:16 AM   #14
Cutie Pie #2
Drives: 2014 Honda CR-V LX
I will have about 20,000 miles on my car before it is even 1 year old. That's driving 50 miles a day 5 days a week to work. I said this on the other post before the hack, I used to work at a auto auction (2004) and there was a one year old at the time 2003 Ford F350 superduty with 350,000 miles on it. It ran pretty damn good for those miles.
Cutie Pie #2 is offline   Reply With Quote
Old 11-26-2008, 01:41 AM   #15
SilverGlow
Drives: 2007 Yaris Hatchback
You are spreading untruths again.
In order for that truck to get 350,000 miles in one year, it would have to be driven nearly 1,000 miles every single day of a year.
I really doubt that was the case.
SilverGlow is offline   Reply With Quote
Old 10-27-2008, 07:45 PM   #16
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
sweet, my car has 50k now, and somehow the brake pad are look like new, have no ideas.
jamal1984 is offline   Reply With Quote
Old 10-28-2008, 02:52 AM   #17
YarisSedan
Compared to most cars our car weighs next to nothing. Less weight requires less braking force less kenetic friction so our pads will last longer than a heaveier car. Also depends on the driver some also. If you like to slam on the brakes every stop light instead of comming to a slow stop to save gas then yeah you may not make it to 100k.
I drive my yaris very very hard. I dont plan on my brakes making it to 40k. My tires ill be lucky to get 10k miles. But im a mechanic and i get all parts wholesale from dealer or even cheaper aftermarket so dosnt bother me much. May plan to put on some performance pads and rotors when the time comes.
Old 10-27-2008, 08:19 PM   #18
nemelek
DWEED
nemelek's Avatar
30 years ago 100,000 miles was a huge milestone. Now it's nothing for a well built car.
Toyota Maintenance at Dealership? fmicle DIY / Maintenance / Service 18 03-17-2012 12:27 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 07:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 11:14 AM
Do I need to hava a 1000-mile maintenance service?? hans_fh DIY / Maintenance / Service 3 11-24-2006 07:13 AM
MAINTENANCE REQUIRED!!! SamDaYarisMan DIY / Maintenance / Service 12 10-10-2006 07:42 PM
