Old 09-26-2006, 06:09 PM   #1
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
need wheel & tire upgrade size advice
i originally wanted to put in the TRD 18" on s sedan but since it comes with 40s. the ride will be too harsh for me
i decided on going for 17s but unsure what is the max size without rubbing
which 1 of the below will fit with no rubbing on stock springs/shocks?
-205/45r17
-205/50r17
according to http://www.yarisworld.com/forums/showthread.php?t=1864 since 7.5 rim width fits, then which setup will work without rubbing?
-215/45r17
-215/50r17
i've seen 50s on a mazda 6 and it doesnt look as bad as showed on 1 of the threads here, 50s on a LB
p.s. has any1 called a wheel store to check if the wheel color matches car color? flint mica to match with - Finish: Anthracite Machined
High gloss grey metal with more of a dark silver look
manborn is offline   Reply With Quote
Old 09-26-2006, 07:19 PM   #2
Hawaiian Bluzman
Chrome is GOOT!
Drives: Polar.WhiteYaris.2dr.liftback
Check-out this site and compare your original tire size with new sizes your looking for this is hw I found what I needed for my rims.
You don't want go with a larger diameter tire or your asking for trouble. try to keep it within 3% then you will be ok.
http://www.1010tires.com/TireSizeCal...?action=submit
Also check-out (Tirerack.com) you can match rims to your car color and get a good idea of what looks good on your Yaris
Hawaiian Bluzman is offline   Reply With Quote
Old 09-27-2006, 12:27 AM   #3
manborn
are u still 34/39?
manborn's Avatar
ya, i tried that but they didnt have the rims i wanted. so, cant color match.
great site man, ty
Wheel and tire question. EddyCocaine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 08-31-2006 12:13 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
