Old 10-19-2008, 01:29 AM   #1
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
Weapon R Header Broke
Old 10-19-2008, 01:31 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
this mostly happened due to the spherical joint being removed when an aftermarket header is installed.... My exhaust guy fixed this for me by adding a new one so their will be some flex
Old 10-19-2008, 01:40 AM   #3
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Seems like the header's flange didn't meet the midpipe's flange well enough and was "pulled" into meeting up and screwed up. Eventually the repeated heating caused metal fatigue that sheared the header's tube at a weak point.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 10-19-2008, 02:10 AM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I thought Weapon R was a descent brand?
PetersRedYaris is offline   Reply With Quote
Old 10-19-2008, 02:17 AM   #5
Malaya1221
Malaya1221's Avatar
Originally Posted by kurokoma-kun View Post
holy crap, sorry to hear that malaya looks like the weld right before sensor bung failed?
not sure yet where it failed kuro, haven't taken out the header yet....from what we could c u r correct, it seems like it broke from the o2 sensor but will take another pic once it's out!
Old 10-19-2008, 03:51 AM   #6
kou
Drives: 08 lb
Originally Posted by Malaya1221 View Post
yes, it's split in half by the o2 sensor!
calling WEAPON R....i need warranty on this!
hey garm, still thinking about the DC header that you got.....might just install the oem header!
Attachment 8427
that wouldnt have happened if you had the springs on those bolts.
Old 10-19-2008, 03:55 AM   #7
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Absolutely. That failed for two reasons, install error, and inferior fit.
Get a DC.
Old 10-19-2008, 04:10 AM   #8
kou
Drives: 08 lb
the only problem with fit is the pipe needs to cut down where they meet if cut prior to install it is fine. that nitto pipe looks to small.
Old 11-17-2008, 01:54 PM   #9
cee_dub2003
Drives: Scion xb
This is Chris W. from Weapon-R. I was reading this post and cant seem to see pictures anymore. But by reading the thread there was! No springs on the bolts?
I don't think there was mention in your email with the pictures that the springs bolts were not installed. Without those springs it will create a bit of stress on the flange. We have taken care of this customer. But for further reference this was a improper installation and we would have not warrantied the header fully.
cee_dub2003 is offline   Reply With Quote
Old 10-19-2008, 03:54 AM   #10
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Oh man, that doesn't look good at all!
Sponsored by: Micro Image
http://microimageonline.com
Old 10-19-2008, 07:07 AM   #11
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
everyone knows weapon R sucks
Old 11-17-2008, 03:37 PM   #12
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
+1
id3379 is offline   Reply With Quote
Old 10-19-2008, 09:25 AM   #13
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
First intakes that get "8hp" gains...now cracked headers...not looking good for them.
Old 10-19-2008, 09:30 AM   #14
Astroman
Modded Moderator
Astroman's Avatar
Yet another reason I'm glad I got a DC header.
Old 10-19-2008, 09:47 AM   #15
Sabretooth
37HSSV
Sabretooth's Avatar
Hell even nobody is having issues with the Megan Headers....and everyone thought that was going to be the first to give problems.
Old 10-19-2008, 09:48 AM   #16
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Megan header here,NP.And it was from the GB way back then.
eco is offline   Reply With Quote
Old 10-19-2008, 11:13 AM   #17
saplaymate
saplaymate's Avatar
Drives: 08' HB
That wasn't the headers failure, thats all from modifying way the pipe mounts!
yes in general weapon does suck
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 10-19-2008, 03:03 PM   #18
llimonce
Drives: yaris sedan
you need the springs.. men .. because without the springs , the torque broke the header ..
the springs are a torque absorber .. be carefull
llimonce is offline   Reply With Quote
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Who got that weapon header? Galavoxx Performance Modifications 1 12-04-2006 09:11 PM
