![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
Spedometer inaccuracy?
Mentioned in another thread:
I'd swear my spedometer shows me going 10-20 miles faster than I'm actually going; has anyone else noticed this, or should I report it to my dealer??? Not sure how to measure this accurately except that yesterday I was just moving with the flow of traffic on the interstate (70 mph; most do 75-80 mph), and it showed me doing 90!!! Not everyone else was also driving a Yaris, either...
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
Mine is off by about 5mph, i noticed it with my GPS, but i don't mind.
'09 5dr
Drives: 2009 Yaris 5-Door Bayou Blue Join Date: Oct 2008
Tire size will make the speedo off, but not that much off.
Let's say your original tire size is 185/60/15, to make the speedo off by 10 mph at 60 mph, you gotta put tires like 165/50/14. I don't think tires that small even exist. I would ask a friend to drive next to you and ask him how fast he's going. If your speedo is off, then I'd take it to the dealer.
2009 5-Door Yaris LB Bayou Blue Pearl 2009 5-Door Yaris LB Black Sand Pearl |
They do substitute 15" wheels for the original 14" when they add the packages (I got convenience and all-weather, only because I couldn't avoid them)... Could that be it?
#5 | |
'09 5dr
If 175/65/14 says 50 mph, 185/60/15 would say 48.35 mph.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Making the asssumption that the speedometer and the odometer are linked together, the odometer is easy to check using the highway mile markers.
Making a decision without following it with an action is still a fantasy. |
Just as easy for speedo too. Hold constant speed between markers and time it.
![]() ![]() Drives: 2008 Yaris LB 5 speed Join Date: Oct 2008
According to my scan guage my spedo is pretty much dead on. Maybe a mile per hour fast.
The speedometer and scanguage get their data from the same place. The Yaris' speedo is purely electronic. If you see a difference between the speedo and the SG, it is because of the SG's lag in reading and displaying data from the OBD port.
It doesnt matter if you have the 14's or the 15's. If it came from the factory then the speedometer is set using the rims on it. I had a 05 Taco with factory 20's which was an upgrade. The regular rim size was 17. My speedometer was set for the 20's.
'09 5dr
Hickman said "If it came from the factory", which means dealer did not change the rim.
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
i'm about 5mph off with the summer tire/rims
Sold the yaris... rocking an 89 vw cabriolet now :) |
Are you guys taking into consideration the overall diameter of the rubber themselves? It really doesn't matter how much off the metal rims are.
#14 | |
No. It doesn't change a thing. A sales guy at Brossard Toyota (he doesn't work there anymore) did the test with 2 echos. a hatchback with factory 14" (175/65R14) and a sedan with factory 15" (185/60R15). They did many tests driving side by side... both at 100kmh, the 15" would over take the 14". The sedan would have to drive at 96kmh to stay equal with the hatch, and the hatch has to drive at 104kmh to keep up with the sedan. The test was done to prove that toyota did not adjust the ECU to reflect the different overall diameter size of the wheel/tire. In fact, to match the 175/65R14, you would need 185/55R15. |
#15 | |
'09 5dr
I always thought Toyota would adjust the speedo according to the tire diameter. I guess my speedo shows 3.3% slower than I'm actually going, but that's no problem.
#16 | |
That's interesting, i should grab a GPS to check this out again. I haven't really checked out my speed with a GPS since i'm not running on stock tire size. And btw, we're allowed 10% error on the speedo, so I do not think Toyota would bother making another part for models with different tire sizes. |
Mine is quite accurate.
GPS, Speedometer and SCII all show exactly the same mph. I have noticed that the GPS unit has a lag in the reading. I am running stock tires on steelies.
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
Wow, y'all have given me a headache; did I mention that I'm math-challenged??? It doesn't bother me; I just move with the flow of traffic anyway, keeping a safe distance behind whoever's in front of me.
Certainly not going to take it back to the dealer and complain; too happy.
