Old 11-15-2008, 10:07 AM   #1
craigq
Drives: '07 Yaris, '12 GLI
Post Updated: Compiled 1NZFE Used Oil Analysis
Updated tab-delimited text file is attached and the Excel spreadsheet can be found here for those who have issues importing the text file...
craigq is offline   Reply With Quote
Old 11-16-2008, 08:49 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Craig, Nice work putting this together. Most noteable is the factor of ten increase in wear material during break in; well into 15K on the odo. The High end synthetics seem to do well in my weighted analysis of sum of critical wear metals/miles on oil * 1000. My big surprise is the lads with the 10K+ OCI showing good results though they may be utilising special external filtration systems beyound what a mere mortal would bother with.
Sonja's Papa
Old 11-25-2008, 01:36 PM   #3
TheSilkySmooth
Bump - No one wants to read spreadsheet and comment? No interpretation?
Old 11-25-2008, 01:40 PM   #4
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i blow through oil so fast that it gets changed in about half it's life :D
edit, did this for you guys :)
http://spreadsheets.google.com/pub?k...lNeW-ulpouEJcA
Old 11-26-2008, 02:39 AM   #5
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
I found the high silicon numbers on so many of the samples to be a bit disturbing, especially the numbers >200. I've run 11,000+ miles on a motorcycle oil change and had numbers less than 10. My understanding is that high silicon numbers indicate bad air filtration.
But after re-sorting by vehicle mileage, it became apparent that most of the high silicon number vehicles had very low mileage. In this case, I'd guess that the high silicon count comes from break-in contamination. It looks like this illustrates a very good reason to change the oil very early. I wouldn't think 100 miles would be too soon.
Also notable was that the three samples using the bypass filters were not showing the great numbers that you might expect, and the silicon count was high. I think they need to change the oil more often...
Reddog99 is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-24-2009 12:30 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 04:25 PM
