![]() Drives: 1.4 D4D Join Date: Jan 2014
Hello ppl!
I own a Yaris d4d 2013 90hp. I could like to know if anybody have put a bigger turbo...a bigger ic....a bigger fuel injectors. What modifications i can do to gain over 50hp? I know about chips but i could something more effective. THanks a lot
Anybody?
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
we don't have the diesel in the USA, but those are the types of things you would do. i would think the first thing would be a ECU as toyota has a way of keeping things mellow. you could probably squeeze 10% gain in HP and +15% torque from stock. then when you add on larger things you can appropriately adjust for the gains. IMO
The thing is that i have already a chip on it....but... i want more.... +50 at least...
But i can find on net one single person that have done any modification with bigger turbos etc etc in order to have someone to show the right way..... |
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
If you want to get 50+ more HP, buy a new car! Realistically though, if you plan on increasing the rated power by more than 50% you will need to do a lot of mods with the right supporting mods. Bigger turbo, bigger IC, tune, engine building, etc. At the end of the day if you want a car with 140 HP just buy a corolla, celica, matrix, civic, etc it'll come up cheaper in the long run.
no, not chip. stand-alone computer. full engine control module. then, the largest intercooler you can fit. turbocharger might be slightly bigger, most likely a different impeller only. i wouldn't go super huge and loose all your low-end, that always sucks. stock should be close to perfect. propane injection is a good adder for diesel, so is a water/methanol injection. if you add both of those you will get your +50hp...
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 31 | 10-20-2025 10:08 AM |
| Engine turns over but doesn’t start on a Yaris VVTi | YarisVVTi2002 | DIY / Maintenance / Service | 50 | 03-30-2025 09:27 PM |
| Engine rebuild or engine change? big dilemma.... | Elwe2k | DIY / Maintenance / Service | 28 | 02-02-2017 11:21 PM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-13-2010 12:47 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 08:11 PM |
