Old 07-28-2006, 07:50 PM   #1
FlintS
FlintS's Avatar
Drives: 2007 Yaris S Sedan
More Companies with Mods
I just got the car back from progress. They are going to be making a rear sway bar and springs for us. Release date of about 4 weeks for the bar, and about 6 weeks for the springs. Not decided yet, but they are thinking a 1.8" even drop, with qutie a bit higher spring rates then stock. On a side note, The sedan was even with the liftback with front weight, but the sedan was 40 lbs lighter in the rear. Kinda odd I thought.... I will keep you guys updated...
FlintS is offline   Reply With Quote
Old 07-28-2006, 08:34 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Do the sedans come with a rear sway at all?
Will they be making a rear sway for the Liftbacks (we dont have one.. period!)?
Old 07-29-2006, 07:38 AM   #3
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Are you saying that the sedan is lighter than the liftback?
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-30-2006, 01:23 PM   #4
FlintS
FlintS's Avatar
The sedan is 40 lbs lighter then the liftback... And the sway bar will fit the sedan and the liftback. The cars share the same suspension....
Old 07-30-2006, 06:04 PM   #5
Chris07LB
Chris07LB's Avatar
I dont understand how that could be..
But you are correct!
Curb Weight
Liftback = 2,290 lbs.
Sedan = 2,288 lbs.
Old 07-30-2006, 07:26 PM   #6
Chaad32
Chaad32's Avatar
It doesn't make sense to me either. I guess our rear hatch just weighs a ton...
2007 Liftback
Blazing Blue
Old 07-30-2006, 07:52 PM   #7
FlintS
FlintS's Avatar
Pretty odd for sure. The same width, a little shorter ( the Sedan), but way longer. All I can think of is the glass.
Old 07-31-2006, 12:53 AM   #8
johnnyfive
johnnyfive's Avatar
read some where that the sedan is about 2 inches narrower, 2 inches shorter(less tall..), and 2 inches longer
johnnyfive is offline   Reply With Quote
Old 07-31-2006, 10:07 AM   #9
FlintS
FlintS's Avatar
Same width as far as I know, but def shorter height and londer length
Old 07-31-2006, 03:09 PM   #10
rstb88
rstb88's Avatar
Drives: Silver Hatchback
msn autos says its .2 inches skinnier
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 08-01-2006, 01:32 AM   #11
johnnyfive
johnnyfive's Avatar
i knew it was 2 something or other ;)
Old 08-01-2006, 05:13 PM   #12
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
I wouldn't be too surprised about the weights- hatchbacks are usually heavier than their sedan counterparts (the Acura Integra 4 door sedan is lighter and stiffer than the hatchback, the 96-00 Civic sedans are lighter than the hatchbacks and coupes, and so on). Sp33dy and FlintS are both right- glass and hatchback doors weigh a ton, and there is extra bracing to make up for the smaller/more compact pillars.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 08-01-2006, 06:35 PM   #13
rstb88
rstb88's Avatar
ya hence the HUGE C Pillars
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
oil companies profitting... hhcchen Off-topic / Other Cars / Everything else Discussions 22 08-08-2006 08:44 PM
Mod's List riceboy General Yaris / Vitz Discussion 43 07-25-2006 09:49 PM
Dealer MOD's silverRS General Yaris / Vitz Discussion 8 05-08-2006 04:18 PM
