Old 12-17-2008, 03:33 PM   #1
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
Chip Hack!
Yo Guys,
I found something and I want you guys to have a look at this, maybe this can help with turbo charging or adding a blower...
http://www.powerenterpriseusa.net/pr...con/camcon.htm
Let me know, I want to do the turbo kit preferably as I can install this my self!
I just need some info... and I am not doing anything if the ca can not be tuned, I need full capacity.....
:e vil:
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 12-17-2008, 04:04 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wow that was an interesting read for me...hmmmm
better to get this than the blitz controller..
Old 12-17-2008, 04:13 PM   #3
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
http://www.yarisworld.com/forums/showthread.php?t=11471
blitz unit and camcon are NOT the same thing
Old 12-17-2008, 04:17 PM   #4
marcus
toyota
marcus's Avatar
its not but for the cost which is almost the same id rather get this one rather than the blitz..i believe they plug on the obd, u cant have both..
Old 12-17-2008, 04:19 PM   #5
mikenacarato
SIPNDEW
Drives: 15 STI
the camcon you have to tap into your wires that go into the ecu. the blitz unit attaches to the tps on the accelerator pedal. you can have both if you choose, the blitz unit will override any throttle changes made by the camcon though if any at all. the camcon controlls the valve timing it appears.
Old 12-17-2008, 04:26 PM   #6
marcus
toyota
marcus's Avatar
oh i see...
Old 12-17-2008, 04:30 PM   #7
mikenacarato
SIPNDEW
Drives: 15 STI
the instructions seem pretty straight forward and i was curious about this unit myself, so if you go that route keep us updated. i would love to know someone who has it on a yaris. :)
Old 12-17-2008, 05:09 PM   #8
N3misiS
N3misiS's Avatar
I wil try and get hold of it and let you guys know, I just thought that
it was quite interesting....
Since it controlls A\F, VVT-I and Throtle....
It could be perfect! because it was tested on the Scion and Yaris and worked!
THat is a top A if it works!
I am in SA so it might be hard getting this...
But I have some connections.
Old 12-17-2008, 05:18 PM   #9
mikenacarato
SIPNDEW
Drives: 15 STI
the camcon will not do anything with your throttle input. it only controls a/f and vvti
Old 12-17-2008, 05:25 PM   #10
Old 12-17-2008, 05:49 PM   #11
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You still can't adjust timing advance, which is critical.
Old 12-17-2008, 06:05 PM   #12
kou
Drives: 08 lb
advance or retard timing +/- 20 degrees ,is what i read.
Old 12-17-2008, 06:37 PM   #13
yep, that's what it says. and that it's designed to work with vvt-i
Old 12-17-2008, 06:58 PM   #14
at3GG
at3GG's Avatar
Drives: 07 metmet LB
hey garm i'll save you the trouble......
Buy it, try it, give us a DIY !!
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 12-17-2008, 07:24 PM   #15
largeorangefont
Break'em off some.
Sorry, was not clear enough.. It does not allow you to adjust ignition timing.
Adjusting the VVTi cam timing is nearly useless.
This is the same technology that the Honda guys ran 10 years ago.... This does not excite me.
Another post hack pic Ryu Photo-Video-Media Gallery 25 07-19-2011 09:26 AM
HOW WAS THE LAST HACK??? willytompkins General Yaris / Vitz Discussion 12 11-12-2008 10:36 PM
Performance Chip njyaris General Yaris / Vitz Discussion 5 07-04-2007 01:19 PM
Performance Chip *to funny* Imagine Off-topic / Other Cars / Everything else Discussions 11 05-04-2007 02:22 PM
Umm, is this a rock chip? fantabulousbaby General Yaris / Vitz Discussion 7 01-26-2007 10:22 PM
