Old 03-18-2009, 04:30 AM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
DIY : Spring install
This is to help those that would like to try it themselves
enjoy and be careful.
Old 03-18-2009, 01:35 PM   #2
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
they make it look so simple!
Yawesh is offline   Reply With Quote
Old 03-19-2009, 12:40 AM   #3
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Good link, but removing wipers and associated cowl covers is not necessary.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 01-04-2018, 05:24 PM   #4
Saphe
Drives: Yaris 2010
Agree! Just cut off 1,5 cm of the head of the 6mm allen key and it will attach easily.
Be careful with the front anti roll bar link. If the locknut is rusty it will probably strip the inside where the allen key fits. Also clean the bolts threads so it doesnt make it seize when you are using the wrench.
Saphe is offline   Reply With Quote
Old 03-19-2009, 12:47 AM   #5
YarisSedan
Drives: 08 Yaris Sedan
I did mine without removing the cowl or wiper blades
Old 05-29-2009, 06:09 PM   #6
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
im not sure how you did this..but maybe sedan is different..
Old 05-29-2009, 06:20 PM   #7
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
i did my spring and shock install , earlier in the week , followed the Toyota
PDF to a T , the whole job took about 5 hour's .
that was by myself and taking my time , and taking photo's .
Old 12-28-2009, 10:08 PM   #8
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Took us 3 hours, the rears took 15 minutes to install.....The front, we couldnt find the right tool to get those damn strut bolts out
We had to rig soemthing up with a socket and a allen key..What did you all use??? I didnt have an air gun so we couldnt spin them off really fast like most would have done?
Old 12-28-2009, 11:39 PM   #9
YarisSedan
Its offset/swivels/and ratchets. Just put it over the nut and hold a alen key over the top of the center of the strut with a pipe on the end and turn.
Old 12-29-2009, 12:52 AM   #10
jekqmb
Ya the new suspension tommorow we will be using an air gun , those strut bolts will come right off this time....
Old 03-20-2009, 01:34 AM   #11
detroiter
detroiter's Avatar
Is it possible to do this without the spring compressor? and i'm curious as well, any negative effects to going with the lowering springs? Also, why would lowering springs cause you to need an alignment done since when the car comes stock from the factory without being driven much it doesn't need one?
Old 03-20-2009, 03:50 AM   #12
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
You need the spring compressor to remove the stock front springs safely. If you are installing shorter aftermarket springs you should be able to install the new springs without using the compressor. No compressor is needed for the rear springs.
Old 03-20-2009, 10:15 AM   #13
REM
REM's Avatar
Drives: 2012 Nissan Leaf SL
Does anyone know how much I could expect to pay to rent a spring compressor?
I have been toying with the idea of lowering my Yaris, but the cost of install that I was quoted is more than I would want to spend. If I could do it myself lowering will be a much more feasible option, even if it took me all day to complete the job.
Cheers,
Ryan
REM is offline   Reply With Quote
Old 03-20-2009, 03:33 PM   #14
gwasabi
Drives: 07 Blazing Blue LB
You can do it 808 Brokanic style. Use a C-clamp and Be REALLY REALLY CAREFUL with it. I mean REALLY REALLY careful. You get hit by one of those springs....man it'll leave a HUGE HUGE bruise. but yea......brokanic style use c clamps lol
and I think stock alignment on our car is 0 toe and 0 camber but don't quote me on that...
gwasabi is offline   Reply With Quote
Old 03-21-2009, 06:58 PM   #15
yarstar
Drives: 2008 Absolute Red HB
Autozone will lend you the tool for NOTHING. All you have to do is leave a deposit for them.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 01-31-2013, 11:21 AM   #16
Yarflana
Drives: 2008 Base Model
Maybe I will do this after all. I was flirting with not lowering the car, but putting better struts on the front...now, it may make sense to lower it since you have to remove the spring anyways. I am only concerned about rub.
Yarflana is offline   Reply With Quote
Old 03-20-2009, 11:53 AM   #17
detroiter
detroiter's Avatar
I'd still like to know what the cons of using lowering springs are and also the reason for why one would need an alignment after installing them?
Old 03-20-2009, 12:52 PM   #18
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Your car could bottom out over speed bumps that you could clear before. Stiffer ride the BOSS may not like. Front lip may become intimate with the odd parking curb. Toe in will be effected by the lower ride height.
soloecho2 is offline   Reply With Quote
DIY needed for amplifier for sedan install YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 2 02-27-2009 10:07 PM
TRD spring install pics tristan Photo-Video-Media Gallery 10 02-20-2009 10:33 PM
Suspension install: Spring Compressors? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 09-18-2007 10:59 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
