Old 12-03-2008, 09:35 PM   #1
Stargate YARlantIS
Stargate YARlantIS's Avatar
I need help w/ wheel spacers...Open Mic lol
So...I've been thinking about this for a minute and decided to ask YW members their experience w/ wheel spacers.... I want to get some just don't know about sizing... if you can look on ebay and let me know your opinions, I'd really appreciate it.
http://cgi.ebay.com/ebaymotors/10mm-...2483QQtcZphoto
Visualize whirled peas.
Peace, Love and Good Smoke!
--Tommy Chong
Stargate YARlantIS is offline   Reply With Quote
Old 12-03-2008, 09:39 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
what offset/width wheel do you plan on running?
Is you car lowered?
I am running a 7 in wide +43 offset wheel with 25mm adapters all the way around, and 10mm hub spacers in the rear
Old 12-03-2008, 09:42 PM   #3
Stargate YARlantIS
i have ICW 15" RBI's gunmetal 15x7 4x100
not lowered yet, but will be, i have my megan springs, just haven't had the time to install them yet...
--Tommy Chong
Old 12-03-2008, 09:44 PM   #4
Black Yaris
der Zeck
ok........ what is the offset of the wheels, that is the most important part when looking at wheel spacers
Old 12-03-2008, 09:47 PM   #5
Stargate YARlantIS
my rims
--Tommy Chong
Old 12-03-2008, 09:48 PM   #6
Stargate YARlantIS
I think its +40
--Tommy Chong
Old 12-03-2008, 09:53 PM   #7
Black Yaris
der Zeck
Originally Posted by Stargate YARlantIS View Post
I think its +40
if you are running a +40 offset, you do not want any type of spacer/adapter for the front, it will rub like crazy of you do
on the rear you do not want to run more than a 10-13mm (3/8-1/2 inch)
also need to know what size tire you are running.... smaller tire give you more room to play with
Old 12-03-2008, 09:50 PM   #8
Black Yaris
der Zeck
not to be a dick, but that still does not tell me the offset
Old 12-03-2008, 09:50 PM   #9
Black Yaris
der Zeck
you really need to know the exact offset before looking in to spacers/adapters
Old 12-03-2008, 09:59 PM   #10
Stargate YARlantIS
stock rubber from my steelies 185/65/15
--Tommy Chong
Old 12-03-2008, 10:04 PM   #11
Black Yaris
der Zeck
stock rubber should have been 185/60R15
so you MIGHT be able to run 10mm spacers in the front and 20mm in the rear
you will need extended wheel studs to do so
Old 12-03-2008, 10:13 PM   #12
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
IMO if you are going with spacers go with a good name brand. I'm sure if your just daily driving the car you would have no problem, but just my 2cents
http://www.evasivemotorsports.com/Me...e=Wheel-Spacer
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 12-03-2008, 10:39 PM   #13
kimona
kimona's Avatar
Drives: 2014 White VITZ
I would recommend only hubcentric wheel spacers... Ichiba is a good name, but there are certainly others.
Old 12-03-2008, 11:05 PM   #14
Stargate YARlantIS
Thanks for all the info everyone....Mods can lock this if they want...
--Tommy Chong
Old 12-06-2008, 04:06 AM   #15
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
If you don't need extended lugs, then any cheap hubcentric spacer would work.
IMO, they don't have to be name brand. And BTW, those ebay ones are quite expensive. You can get them for 5-8 bucks depending on the size you need.
Good luck, and let us know.
anonymous user is offline   Reply With Quote
Old 12-06-2008, 06:50 AM   #16
Black Yaris
der Zeck
well if you go as little as 1/4 inch (~6mm) you will need extended wheel studs.... we have very short OE studs
Old 12-06-2008, 04:19 PM   #17
tk-421
tk-421's Avatar
Drives: 5D-07-LB
What if you have 15x6.5 with +38 offset? I really want to add spacers to the rear wheels.
I don't know if this helps or not, but my center bore is 73.1
Old 12-06-2008, 04:22 PM   #18
Black Yaris
der Zeck
you can run 10mm spacers no problem, or possibly 15mm spacers in the rear since you have a thinner wheels.... also depends upon what size tire
