Old 12-08-2008, 05:50 PM   #1
oconna2
Drives: 2007 RED Yaris
Starting Problems
Hi Guys,
I need your help!!!!!!! My mother's 2007 Yaris just will not start. When you try to start it the engine just makes a ticking noise and wont turn over. Its not a battery problem because all the lights are working. I changed the spark plugs and topped up the oil. The oil was VERY low when I checked it. Can anyone help.
Thanks
oconna2 is offline   Reply With Quote
Old 12-08-2008, 05:53 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
sounds like a bad ground.. or your battery has a dead cell..
check ground, double check battery. the clicking is the solenoid not receiving enough amperage to fully throw the starter gear into the flywheel or flexplate
Old 12-08-2008, 05:57 PM   #3
oconna2
I will go back and have a look at the battery. Thanks for the tip
Old 12-08-2008, 07:50 PM   #4
ddongbap
A low charged battery will still turn the lights on. It could still be your battery.
Based on that click sound you're hearing.
Old 12-08-2008, 08:56 PM   #5
AznGouki
Metsu
Drives: NCP91 ; E36
I'd put my money on the battery. Same thing happened to me before and I just refused to believe it was the battery.
AznGouki is offline   Reply With Quote
Old 12-08-2008, 09:31 PM   #6
iwantayarisnyc
Drives: 08 sedan auto
Originally Posted by oconna2 View Post
Hi Guys,
Thanks
if you have a voltmeter check the battery, i forgot what the readings should be....
it could....be the starter...but your car is still so young....
could be a bad fuse somewhere
BUT i place my bets that your battery clamps are not on tightly and/or dirty.
Maybe you should try removing the clamps, negative first. And when replace, make sure the negative clamp goes back on last.
Leave it for couple of hours
Remember, you just reset ur computer, so it can drive differently. Also, i am not responsible for anything bad =)
iwantayarisnyc is offline   Reply With Quote
Old 12-08-2008, 09:39 PM   #7
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Check the battery and then the starter. If its under warranty I would take it to the dealer.
Old 12-08-2008, 09:46 PM   #8
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Battery should read about 12-12.5 volts with the engine off. With the engine running, if the charging system is functional, it should read at least 14.
I agree, this sounds like a bad battery.
Old 12-09-2008, 02:21 PM   #9
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Even if the battery reads 12v or higher... it could still be a bad battery. Voltage is not the only thing that matters... amperage is also key. Its possible for a battery that has been fully discharged, and then recharged many times to no longer hold a full charge. If this is the case, your battery might not be discharging enough energy, or quickly enough to start the car.
Old 12-09-2008, 03:55 PM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
hey i bet it could be the battery! let's have another go-around where we all say the same thing! lol
Old 12-09-2008, 07:29 PM   #11
voodoo22
Drives: Yaris Sedan (auto)
That's quite a battery of answers.
voodoo22 is offline   Reply With Quote
Old 12-09-2008, 08:44 PM   #12
SailDesign
Drives: .
Well, the current crop is, yeah...
Old 12-09-2008, 08:54 PM   #13
ddongbap
Thats a trippppple knee slapper.
Old 12-10-2008, 05:39 PM   #14
natethegreat38
Party like a Barack star
natethegreat38's Avatar
Drives: '08 LB MT
Where do you get your material?? ^^^ Shit's funny!!
i don't feel like creating another signature, yet. Give it another week...
natethegreat38 is offline   Reply With Quote
Old 12-10-2008, 12:59 PM   #15
IllusionX
Drives: 07 Yaris Sedan Aero
i would like to know what he meant by "topped off" the oil....
i just hope it's not filled up to the filler top.. :P
Old 12-10-2008, 04:23 PM   #16
Forrest
Drives: 08 LB BLACK
Batters up
Forrest is offline   Reply With Quote
Old 12-10-2008, 05:39 PM   #17
natethegreat38
Drives: '08 LB MT
BTW- I think it is the battery. HA!
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 09:48 AM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 01:24 PM
HELP WITH NEW 2007 PROBLEMS partenac General Yaris / Vitz Discussion 15 05-31-2007 06:06 PM
some minor problems after installing my HID kit, any professionals? ASHRAF DIY / Maintenance / Service 14 03-09-2007 11:54 AM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 12:50 PM
