Old 12-04-2008, 01:37 AM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
oem mufdlaps
i got the oem mudflaps today and i got the fronts installed but the rears will not light up correctly. they attach by the plastic pin on the bottom side and 2 screws and spring nuts the top. when i put the plastic pin in the mudflap then attach it to the bottom of the bumper it wont line up right along the top 2 holes. any suggestions?
mikenacarato is offline   Reply With Quote
Old 12-04-2008, 01:43 AM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Use a nail gun sorry
What about redrilling the holes.
Old 12-04-2008, 01:45 AM   #3
mikenacarato
SIPNDEW
Drives: 15 STI
i didnt drill the rear holes yet, it has notches where the spring nuts are supposed to go and they dont light up at all, the holes in the flaps sit too high. i guess i could redrill the mudflap holes but if i leave the bottom pin in place theres a gap between the flap and bumper
Old 12-04-2008, 01:53 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
are you sure thay have given you H/B ones and not Sedan ones.
Old 12-04-2008, 02:23 AM   #5
mikenacarato
SIPNDEW
Drives: 15 STI
im pretty sure. the guy at the parts counter there knows me and what i drive so i would imagine he looked it up for me. ill call him tomorrow. i have the fronts on but not the back :(
Old 12-04-2008, 02:43 AM   #6
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
I put my own flaps on on a LB, so I can say for a fact all the holes should line up perfectly, and no gaps anywhere when you install them, front and back.
I was pedantic though and also added a thin layer of silicone caulk on the inside edge of the mud flaps when I installed them to keep them extra-sealed. Basically ran a bead on the outer edge, screwed them down, wiped up the mess very throughly.
And don't forget to spray and clean the hell out of the area with rubbing alchohol before you install them, seriously, you should be able to wipe a paper towel in the area and get nothing off before you consider the spot 'clean enough' to install something like mud flaps. I went through most of a bottle of the stuff and almost a whole roll of paper towels, just swapped the spray-nozzle from some windex over and went to town.
WolfWings is offline   Reply With Quote
Old 12-04-2008, 02:47 AM   #7
mikenacarato
SIPNDEW
Drives: 15 STI
ya i used detailer to clean the surfaces. i know my 09 bumper is different than the 07 and 08, could that be the issue? they arent even close to lining up
Old 12-04-2008, 03:13 AM   #8
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Thinking 99 , i do not know if anyone in the US has seen Toyotas latest,
cost saving ideas.
They realeased a report over here stating as of late 08 early 09 all toyota models where possable will share parts .
ie 09 Yaris sedan and Hatch backs will have the same bumpers ,fog lights and a heap
of other parts, they called it lean manufacturing , saveing cost on parts and assembly jigs.
double check your recepit see if it says 08, or 09 mud flaps.
Old 12-04-2008, 03:43 AM   #9
mikenacarato
SIPNDEW
Drives: 15 STI
i will double check, i know 100% my front end is different than 08s as well as my rear bumper and tail lights even haha
Old 12-04-2008, 04:40 AM   #10
IsLNdbOi
IsLNdbOi's Avatar
Put these mudguards on my 5-door '09 LB and they fit perfectly:
PT769-52060
http://www.trdsparks.com/part_detail...um=PT769-52060
My dealer's parts department got them for me though.
There's also these:
00016-52707
http://www.trdsparks.com/displaypart...&parts_id=1130
Not sure what the differences are though.
Old 12-04-2008, 10:08 AM   #11
mikenacarato
SIPNDEW
Drives: 15 STI
just got off the phone with them and i do have the '08 set (PT769-52060). the pn for the '09 is PT769-52090 but for some reason does not show to be available yet. :(
Old 12-04-2008, 10:13 AM   #12
Chupacabra
Drives: 2009 Yaris liftback
I put them on yesterday along with my spoiler and I can tell you that the bottom hole in the rear does NOT line-up as you mention. Simple fix....mark and drill the holes holding the mud guard on, then affix the bottom with 3m light body trim tape. Worked perfectly. The fronts were super quick and easy.
Chupacabra is offline   Reply With Quote
Old 12-04-2008, 10:15 AM   #13
mikenacarato
SIPNDEW
Drives: 15 STI
well the guy at the dealer said hes calling toyota to see if he can get them and when. if he can get them soon he said i can keep my fronts on and just swap out the rears. ill see whats going on though.
Old 12-04-2008, 11:05 AM   #14
Chupacabra
Is the rear bumper contoured differently from the '08? Keep us posted. Thanks.
Old 12-04-2008, 11:06 AM   #15
mikenacarato
SIPNDEW
Drives: 15 STI
it looks to be. ive looked at mine vs. a buddy here at work with an '08. from what i understand i cannot run jdm tails either :(
Old 12-11-2008, 12:12 PM   #16
The 08 and 09 rear bumpers are different. Back by the tails, the bumper contour is different (the blue one is my 09 and the black one is Sodium's 08). Also, the tails are slightly different in that the 09s taper in where they meet the bottom and the 08's flare out a bit. It looks like 08s or JDMs would fit, but they would stick out over the bumper contour about 1/2" to 3/4".
The 09s have a different connector than the 08s as well. I believe that the 09 connector is a match to the JDM tails, whereby putting JDMs on an 08 required changing the connector.
Old 12-04-2008, 11:16 AM   #17
Chupacabra
Interesting. My flaps look great but I would be very interested to see if the flaps are actually different. They can't be for the front because....those went on like butter.
Old 12-04-2008, 11:20 AM   #18
mikenacarato
SIPNDEW
Drives: 15 STI
ya, i installed the fronts with no problem at all. the rears look like they need to be taken in paint and resized to 90%
Anyone with OEM tweeters integration in A-Pillars ? (SEDAN) mledez In Car Entertainment + Electronics (audio / video / alarm) 10 12-18-2008 12:36 PM
FS: OEM 15" Scion Rims & Tires....Brand New crabbadam Canada 5 11-27-2008 07:14 PM
OEM parts and diagram site? RTW YARIS General Yaris / Vitz Discussion 3 08-24-2007 03:04 PM
wanted - your OEM stereo tc2468 Items for Sale by private party 4 06-23-2007 11:27 AM
FS Various OEM keyless Remote riceboy Items for Sale by private party 0 04-14-2006 03:42 PM
