Old 12-25-2008, 08:27 PM   #1
06vitzRS
Drives: 06 Yaris HB
Brake fluid info...
Some people are talking about using racing fluid (DOT5) in their brake systems. I would not and this is why:
There are 3 ratings, DOT3, DOT4, DOT5. 3&4 are glycol based and 5 is silicone based. Glycol based fluids are hygroscopic, which means they can absorb moisture. Silicone based is not. Any moisture in the system will collect in the lowest points of the system. The moisture winds up in the wheel cylinders and calipers. DOT 5 should not be used in ABS systems because the water can collect in the valves of the ABS system, corroding them and rendering them inoperative. Dot 5 is also more prone to trapping air in the fluid, especially when agitated, as happens in an ABS hydrolic controller or pump.
If you are going to use DOT5, at least change it often. DOT4 is good enough and way less to worry about.
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 06:23 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 08:16 PM
Engine dress up - brake fluid resivoire cap? YarisSedan Cosmetic Modifications (Exterior/Interior) 5 11-15-2008 08:59 AM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 02:44 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
