![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Installed hood deflector, in-channel vent visors and hood seal.
Finally installed my hood deflector and WeatherTech in-channel vent visors today.
The hood deflector I purchased from ToyotaPartsStore. It's the exact same one sold by Toyota in Canada and that Garm / cali yaris sells in his MicroImage Online store. Here it is: ![]() The deflector does protect most of the leading edge of the hood (a detail which usually can't be seen unless you're up close) and obviously protects a portion of the hood's surface. Here are the WeatherTech in-channel vent visors: ![]() I also did Kou's hood seal mod. I did it a little differently though. I ordered 4 feet of this: http://soffseal.com/SearchByPart.asp Part #: E006A and just stuck it on. This weatherstrip comes pre-attached to double sided 3M weather-proof tape. 4 feet was a little long so I just cut it to the length I needed. ![]() ![]()
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
Looks awesome. Being in Canada, I have the same deflector installed as a dealer option when I bought the car. Functional and visually appealing.
I also have the in-channel window visors for my 5-door. These are Genuine Toyota visors, supplied as a dealer option. They have the Toyota logo in the same location as the Weathertech logo that yours has. Stock photo. |
keep us updated on the fitment of the visors from WeatherTech. Some have complained about them falling off
I have a feeling the same company makes WeatherTech's and Toyota's in-channel vent visors. Both have that little part at the front that go down for the front windows. When I had a 3-door LB, that part on both sides kept pulling out on their own. Ended up returning them. I believe another member here actually had his WeatherTechs fall out while driving on the highway.
With these new WeatherTechs for the 5-door LB, the two for the back doors both have double sided tape pre-applied. For the front doors, I put strips of 3M double sided weather proof tape on the part that goes downwards to keep them from pulling out on their own this time. |
I am curious on the extra hood seal....... will it do anything that will help? I would worry it would freeze the hood shut in the ice around here.
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
![]() Drives: 03 Echo, 04 Scion xA, 02 Range Join Date: Dec 2008
I just bougt a 2009 3 door lift back. Has anyone purchased either an auto vent shade or weatherteck windo rain deflector kit by either of these vendors for the 2009 2 door model? TIA , Mark S
Drives: 2009 Yaris liftback Join Date: Nov 2008
![]() ![]() ![]() Drives: 2008 Yaris Liftback Black Join Date: Oct 2008
Looks good. =)
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL Representing The Midwest! http://www.cardomain.com/ride/3132598 |
#9 | |
The WeatherTech and AutoVentShade in-channel vent visors for the '07 and '08 LB will fit the '09 3-door LB. |
#10 | |
TRIM HUNTER
#11 | |
Any seal will freeze when it's cold enough and there's residual moisture and/or moisture period. I don't recommend it for that reason |
Why don't you try it? The weatherstrip is cheap. You obviously live somewhere where it cold enough for things outside to freeze.
#13 | |
Now... if you live somewhere where it doesn't freeze, this mod is just fine. |
I didn't know Siennas came in four lug.
TRIM HUNTER
