![]() ![]() Drives: 2009 Yaris Sedan (Black) Join Date: Nov 2008
17" rims and fuel economy
hey guys...anyone here running their yaris on 17" rims? although i love my FE on my stock (15" steelies), i am starting to consider putting 17" rims on there because of the looks. however, how drastic will this change affect the FE? lets assume that the 17" rims are about 20-21lbs each, which should be about 3 or 4lbs heavier than the stock 15" steels (which are around 17lbs each if im not mistaken). with that total of 12-16lbs heavier wheels, how much will that hurt the FE? and does it also depend on the diameter of the tires as well? i plan on using 205/40/17 tires. im not sure how much they should weigh tho. maybe this quetsion is a little too hard to answer =P if anyone has their own experience with 17" id like to hear them tho at least ! thanks
Just call me Ray, better?
i love my 17"s.... and the mpg didnt change much... but the turning radius is a bit decreased... i dont know if me being lowered has anything to do with the mpg
ahh i love the yaris turning radius! how much do your 17"s weigh?
all 4 was 44lbs... with tires it was i believe about 52-56lbs range... on 205/40/17
well, i have 14" steelies which weigh around 14lbs (i think 15" steelies are 15 or 16lbs) with 185-60-14 fuzion hri's
crandall has 17x7 tenzoR rims w/ 215-40-17 general exclaim uhp tires - - i think the rims weigh 18 or 19lbs....so not THAT heavy by 17" standards we're both 5 speed, both live in the same town and he gets about 50km (+/- 30miles) less per tank than i do. he's dropped on tein basic coilovers and i KNOW he takes it easy accelerating....and he doesnt really speed. i drive moderately aggressively and i take off quick from lights. i also have an intake. ive driven crandalls car too....i notice HUGE acceleration and braking difference between our two car (intake or not). heavy 17's, in my opinion, arent a good idea for small, light cars with small engines and low hp - - if youre concerned about acceleration, braking or economy, that is...
I'd keep the original 15 inch with snow tires and get summer tires on the 17's for spring,or do you plan on getting snows for the 17's=very expensive.
what about all seasons on 17's?
But remember, if you add 17" wheels then you need to multiple the distance driven by 1.07 to get the exact mileage, due to the larger wheel diameter...
So when I drive an "indicated" 350 miles, in reality it is 374.5 miles... Cheers! M2 |
#11 | |
oem is 185-60-15 205-40-17 are within 1.23% of the oem rolling size 215-40-17 are within 0.125% really, youre only going about 1% farther rather than 7%...
#12 | |
Go to this web site and submit those two sizes in, and you will see that the stock tire has a circumference of 72.09 inches (1831mm) whereas the larger tire I am running has a circumference of 77.31 inches (1963.6mm). That's a diameter difference of 6.75%. Do the math and you will see the tire travels a distance of an additional 5.22 inches per rotation over the stock tire. As the odometer is set for the stock tire, you must add the addition of 7% (rounded up) to the odometer distance traveled. Last edited by MadMax; 12-18-2008 at 09:58 AM. |
#13 | |
#14 | |
Plus, I own a Jeep, so I am very familiar with oversized wheels and tires! It is very common in the Keep community for people to put huge tires on their rigs. Besides suspension modifications, the only real requirement for larger sizes is regearing (for going from 29" tires to 35" or larger); but that is not an issue here. The stock Yaris with an AT can easily handle 17" wheels, and you can even lower it by changing out the springs to some degree without having rubbing issues. People all over this forum have done this, and there are numerous threads about it Cheers! M2 |
I didn't get that message, and numerous people on here have put on 17" wheels without problems. Plus, I may be relatively new to the Yaris; but this isn't my first rodeo! The Yaris is light enough and the brakes adequate to handle the larger wheel. You may lose a little lower-end acceleration but you gain it back on the upper end.
As for Jeeps, I hope he regeared more than his speedo if he offroads, as his differentials are going to explode one of these days if he puts the stress of 35s on them with the stock gearing! He needs to regear to 4.88 with 35s to get the low-end back. Without that, he'll be very slow off the line and be downshifting at every hill even if he doesn't offroad. |
#16 | |
as for my buddies jeep, its fairly extensively modded...he knows what he's doing....lol, i think! his screen name is highonlifeandglue on jeepkings.ca
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Welll.... One of the big flaws to current tires as I see it is the width. If wide tires were efficient, then bicycles would have wide tires, right? Every try pedalling a bike with fat, small-diameter wheels? It ain't easy... Same thing applies to any wheel: the larger the diameter, the less rolling resistance. The narrower the wheel, the less rolling resistance. All this rolling resistance has to do with fuel economy.
As far as snow is concerned, the same thing applies: my neighbour goes over a gravel pass in the winter, and none of the 4x4s, no matter what tires they have, can follow him. What's he driving? A Model T. 30" diameter, 3 1/2" wide tires. He can drive through a foot of snow with no chains or other traction devices. Gee, why is that? I had a set of late-technology snowtires on my Volvo; they worked, but now I have a set of narrow-section (75%) tires on there, and they are much better in the snow (they don't plow as much), and my FE went up. Something to consider... |
What's up with all you Canucks?!? Do ya gotta argue about everything?!?
![]() Just kidding, of course! For TLyttle, I do understand that a wider tire offers greater rolling resistance, therefore reduces fuel efficiency; but you neglect to mention that there are benefits over a wider tire such as cornering traction. By the way, you got it confused, the diameter of the tire is the distances encircling the tire, not the width. We are talking about taller tires on here, not wider ones; but the truth is that taller tires do require greater effort to get moving, hence the need to regear in Jeeps when adding much larger wheels. For my buddy thebarber, the speedo and odometer being off by 7% is not a big deal. I can easily computer how fast I am going and I also have a GPS that gives me a more accurate reading than any speedometer would (I left the speedometer error discussion out of this as it applies pretty much equally to all cars). I work with a guy who has a stock Yaris with an AT, maybe one day I will challenge him to a drag race so we can see how much faster the smaller tires make it. I doubt it is much, and I would have him at some point as the taller tires will give my car a greater top speed. But all that is a moot discussion when talking about an economy car such as the Yaris. The larger wheels are more of a 'looks' thing than they are a 'performance' mod. And I am not one of those 'hypermilers' who play every trick in the book to squeeze an extra mile or two out of a gallon of gas. A gallon costs $1.45 here in Texas at the moment, and I would rather enjoy driving the car. I speed (80+ MPH), I take off from stops faster than a snail and I don't shut down at stop lights or drag off the back of large trucks. I bought my Yaris because it is a fun little car to drive, and I put the bigger wheels and tinted windows on it to make it unique. I parked next to a stock Yaris the other day and there is a distinctive difference between it and mine. And most of all, I am happy with it. That's all that matters. Oh, and if I want performance, I jump on my 150 HP litre-class sportbike. After riding that, nothing else feels fast... |
| getting bigger rims = odometer/speedometer changes? | songa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 11-27-2008 01:43 PM |
| 17"&18" rims and effects? | microbe__ | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 11-23-2008 01:09 PM |
