Old 12-27-2008, 11:18 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Dealer overflows engine oil by like one quart..........
do these guys even check how much oil they put in?
on a flat surface, after overnight, i check the engine oil
it's like one inch OVER the high "dot"
what should i do
Yawesh is offline   Reply With Quote
Old 12-28-2008, 12:15 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
the yaris takes 3.75QT of oil. Royal Purple is sold in 0.965(?) quarts, anyways, it adds up to something around 3.8QT when filled with 4 bottles.
the dip stick does go pretty well over the "high" dot over night. I will check it again tomorrow morning...
Old 12-28-2008, 12:16 AM   #3
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
so there's no accurate way of checking it?
Old 12-28-2008, 08:53 AM   #4
xpeteyjtx
Drives: 07 BB Yaris
what should i do
An inch over would be too much for me (whether it would do critical damage is a question for the people who designed the engine). I would take it back. It is safe to say that they added about 5 quarts. Most dealers seem to overfill the oil. Unfortunately, some people think that every car takes 5 quarts.
I usually just add 4 quarts and it ends up being just over the full mark with a new oil filter.
xpeteyjtx is offline   Reply With Quote
Old 12-28-2008, 09:38 AM   #5
Chupacabra
Drives: 2009 Yaris liftback
I just did an oil change and can tell you that it should take around 3.5 quarts.
Chupacabra is offline   Reply With Quote
Old 12-28-2008, 11:06 AM   #6
gid
Drives: '08 Yaris sedan , '08 Liftback
+1
3.5 quarts of oil brings both our YARII to or a tad below / above the FULL mark . You could either take it back or change the oil filter yourself 1 > 3 times , also loose oil when you remove filter . The oil filter holds about 4 ounces of oil . They don't let vehicles drain that long , gotta get 'em in and out . Profit to be made yeh know . That's why I do O.C.s at home . At least I know what I've done . Or do I ? Ain't gettin' any younger .
gid is offline   Reply With Quote
Old 12-28-2008, 09:53 AM   #7
tuckevalastin
tuckevalastin's Avatar
Drives: 2008 Yaris Sedan
I put four quarts and that puts it just over. Never bothered to check after a dealer change.
Old 12-28-2008, 11:15 AM   #8
gid
or go to PEPBOYS , AUTOZONE , ADVANCE AUTO PARTS , or WALLY WORLD and get the 5 quarts of oil and filter for $15.99 or less and D.I.Y.. Here's some specials , http://www.bobistheoilguy.com/forums...oard=33&page=1 . That's if you have the place , tools , and knowledge to do it . GOOD LUCK
Old 12-28-2008, 04:02 PM   #9
nemelek
DWEED
nemelek's Avatar
I would take it back. Tell the service manager that trust in their dealership for future service work is broken. If you play your cards right you might get the next oil change free. Your experience is why I do all my own service work.
Old 12-28-2008, 11:28 PM   #10
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
thanks, to everyone.
so far i have driven like 350 miles since the over oil change, bad bad bad?
Old 12-29-2008, 12:16 PM   #11
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
You will kill the motor, catalytic converter unless you get it drained SOON. You are creating and sucking in massive amounts of oil - and foaminbg up the oil. the Manuals states this will cause engine damage AND IS NOT COB+VERED UNDER WARRANTY ... you could end up with a 25MPG yaris any moment. NO SHICK!
TheSilkySmooth is offline   Reply With Quote
Old 12-29-2008, 01:43 AM   #12
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I let mine drain for a while and use about 3.8 quarts and its perfectly to the full mark or a little below. I think they dont let it drain enough and then they add the 4 quarts.
slvryaris is offline   Reply With Quote
Old 12-29-2008, 03:34 PM   #13
gid
+1 , get it done soon as possible . Being so full could harm seals , gaskets , and seep past the rings due to extra pressure within the motor affecting emmision system .
Old 12-29-2008, 04:09 PM   #14
NJBob
NJBob's Avatar
Drives: 2008 Yaris Liftback
Lightbulb
+2 Plus if you take it back in and there's any damage incurred later as a result of their negligence, you got it on record. Word.
Old 12-29-2008, 04:32 PM   #15
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
I have yet to find a dealer that isn't sloppy about their oil changes. Two Jeeps I have that get dealer oil changes are always overfilled. I have to take them home and loosen the drain plug and bleed off the extra till it's back to the full mark. Last time they dumped oil all over the motor and it ran down the back side-very smelly for a week no matter how much I tried to clean it off. This car has never seen a dealer yet-I do my own oil changes since it's simple and there are no grease fittings to worry about. If you don't have the place or means to bleed it off yourself-try taking it back to the place that did it. As already stated here, it is not good for the engine/seals. Good luck.
UTVitz is offline   Reply With Quote
leaky seal on engine? oil overfill? jeff69dini DIY / Maintenance / Service 23 06-07-2010 12:52 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
don't think the dealer changed oil filter on first change gonzo452001 DIY / Maintenance / Service 0 01-13-2007 11:44 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
