Old 01-01-2009, 12:18 PM   #1
bosbik
in the toilet....
bosbik's Avatar
Drives: Vios
Does Rim offset affect performace?
does rim offset have any effect on a cars performance, positive or negative effects?
thanks!
bosbik is offline   Reply With Quote
Old 01-01-2009, 01:36 PM   #2
well the further out the wheel is, you can gain some stability in high speed turns, but you'll really only feel the difference on the racetrack (that's one reason why many race cars use wide bodies)
Old 01-01-2009, 02:44 PM   #3
bosbik
in the toilet....
bosbik's Avatar
Drives: Vios
thanks..so is it safe to assume there is no effect on engine performance?
Old 01-01-2009, 03:58 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
no engine preformance, just handling
I went from +43 front +30 rear to +18 front +5 rear..... and I noticed a HUGE difference even durring everyday cornering. But you can't run that low of an offset on the Yaris
Old 01-01-2009, 04:16 PM   #5
bosbik
in the toilet....
bosbik's Avatar
Drives: Vios
cool info..thanks guys!
one more question..what is the lowest possible offset on a yaris/vios sedan?..is zero offset possible with a 17 or 16 inch rim?
Old 01-01-2009, 05:05 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
Sure... if you want the wheels/tyres poking way out past the fender lips.
With 17's, I wouldn't run any lower than ET42 with 205 rubber.
Same for 16's, unless you run 195's with ET38-40.
Old 01-01-2009, 06:54 PM   #7
ddongbap
thanks!
Yes.
Sometimes.
Old 01-01-2009, 08:51 PM   #8
nerd_vitZ
Drives: 08 silver streak mica LB
well, you can have the offsets that high and have minimal rubbing. but, technically on 16s, you can run from 30-25mm to make it as flush as possible and have rubbing, but not TOO crazy. but it matters size of rims, how much drop, and size of tires.
nerd_vitZ is offline   Reply With Quote
Old 01-01-2009, 08:53 PM   #9
nerd_vitZ
and dont forget that on the yaris the wheels need a "staggered" offset to get the "flushed look"
Old 01-01-2009, 10:26 PM   #10
Black Yaris
der Zeck
also depends upon the width of the wheel & if you stretch tires or not
Old 01-02-2009, 06:25 AM   #11
bosbik
in the toilet....
bosbik's Avatar
Drives: Vios
thanks for the reply guys!..can i put 195 tires on a 16's rims with 7in width on the rims or is it better to use 205 series tires?
Old 01-02-2009, 06:46 AM   #12
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Offset does affect handling because a wider track reduces the roll angle which improves stability. Read It doesn't come without a price, however. Every hub and bearing assembly is engineered to work with a specific wheel offset, so if you vary too much from the design offset, you risk wearing wheel bearing prematurely or possibly even overstressing the hubs.
Stick within 5mm or so of stock offset and you have nothing to worry about.
Old 01-02-2009, 06:53 AM   #13
bosbik
in the toilet....
bosbik's Avatar
Drives: Vios
cool!..thanks loren...:D
Old 01-02-2009, 03:31 PM   #14
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
or buy some rear hub spacers :D
Originally Posted by xnamerxx
you nailed it sir.
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 11:09 AM
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 01:09 PM
offset... Keymaster Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-01-2007 02:53 AM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 04:25 PM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 04:43 PM
