Old 12-17-2008, 06:45 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Has anyone fashioned brake cooling ducts for the LB?
I have a set of LB foglights that I recently purchased but now instead, I am toying with the idea of fashioning cooling ducts for the front brakes via the foglight shroud. This would be to support track days should I ever start racing the road coarses.
1. Has anyone built cooling ducts themselves and have pictures of how they did it?
2. On rainy days, wouldn't ducting from the foglight area potentially spray water droplets on your front brake area? That can't be good.
Old 12-17-2008, 07:04 PM   #2
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
brake cooling duct
remember "loren" making some kind of cooling duct too, might want to pm him!
Old 12-17-2008, 08:51 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Your brake rotors get drenched every time you go through a puddle, it's not a big deal. (well, it CAN be a big deal if you're on a race track and get the brakes REALLY hot, then hit a puddle... that could crack a brake rotor... but not an issue for street driving)
I thought I posted about this somewhere, but I'll be damned if I can find it... oh wait... the forum crash. Yeah.
Anyway, I ran 3" dryer duct straight back from the foglight holes, cut a hole in the fender liner and the results were very good. I ventilated the foglight covers, and the ducting is held in place with zip ties.
I used to get a lot of brake fade at the track. Now I don't.
Here ya go:
Old 12-17-2008, 10:34 PM   #4
LtNoogie
LtNoogie's Avatar
Thanks Loren. On the third picture, it's hard to tell from which angle you shot the picture ...behind the left front tire? Was there much thought as to the aiming of the duct or was the thought just to get any forced airflow onto the rotor?
I also assume that one needs to take care to route the hose so that water does not collect in the tube.
Old 12-17-2008, 10:52 PM   #5
Loren
What?
Loren's Avatar
Third picture is in front of the RF tire. The end of the duct is cut at a slight angle. I did orient the duct to point just to the inside of the tire tread when the wheels are straight. The point was to cool the brakes, not the tire tread.
It's an aluminum tube, I'm not worried about water collecting in it. Never gave that any thought at all.
Old 12-17-2008, 11:06 PM   #6
LtNoogie
LtNoogie's Avatar
Ok, thanks. Saturday is Home Depot day. I've got to get myself a Dremel and parts.
Old 12-17-2008, 11:53 PM   #7
jkuchta
Drives: 2007 Yaris hatch (red)
I'll be doing the same thing once the foglight shrouds get here from Canada. The pilot shop at Brackett Field (in Pomona) has high temp ducting (the orange silicone stuff) by the foot if anyone is interested.
jkuchta is offline   Reply With Quote
Old 12-19-2008, 12:36 AM   #8
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Don't waste your money on the silicone stuff until you perfect your tube routing. If your rim or tire hits it, it still gets destroyed.
Get the RV waste tubing in the RV section at Wal Mart. It is a few bucks, and one tube will probably do both sides on a Yaris.
I have to replace it occasionally on my Cobra. The cheap tubing holds up to the temperatures just fine. I have no need to go to the expensive stuff.
Old 12-18-2008, 12:03 AM   #9
LtNoogie
LtNoogie's Avatar
Now, I just have to sell the LB foglight kit I just bought.
Old 12-18-2008, 10:17 AM   #10
Loren
What?
Loren's Avatar
FWIW, I didn't use the dremel on the foglight covers. Just used a utility knife and somehow managed to not cut off my fingers. It's soft plastic, cuts fairly easily. A high-speed Dremel is going to have the tendency to want to melt the plastic and make a mess.
Old 12-18-2008, 11:20 AM   #11
The Dremel I have is variable speed -- shouldn't be a problem.
Cool project!
Old 12-18-2008, 10:55 PM   #12
03Z33
03Z33's Avatar
Drives: TCR10
These cars have brakes? What for??
Looks great Loren! I'd do the same if I ever used the brakes
03Z33 is offline   Reply With Quote
Old 12-18-2008, 11:01 PM   #13
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
What do you play bumper cars instead
Old 12-19-2008, 01:13 AM   #14
LtNoogie
LtNoogie's Avatar
Thanks for the photos, guys.
Old 01-11-2009, 12:44 PM   #15
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
very impressive mods guys, good luck with all of your projects!
Wanted: Forced Induction
Old 01-11-2009, 12:45 PM   #16
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
largeorangefront-how is the tubing held in place in front of your brakes? is that a custom bracket you made?
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
