#1 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
damp engine problems?
today there was a lot of rain
and i didn't run my car the other day so basically it had been sitting at a slightly declined driveway with the engine pointing down for 2 days without being run and in a very wet and humid climate. I turned it over and it stuggled to keep running smoothly... so I shut it off. waited a few minutes outside of the car and could smell a burning sort of smell. second attempt.... started, ran rough.... then eventually stalled.... third attempt, started, ran rough, rev'd it a little and began to run smoothly. I poped the hood and noticed that my windshield fluid container was open??? I doubt that had any effect, ALSO there was some smoke (or steam) coming from the back right portion of the engine... after a whille it stopped and the car ran perfectly.... I guess the engine just got damp???? Any thoughts?
-Jen <3 ![]() Quote:
the only thing i can think of is you belt got wet and was slipping so the alternator wasnt giving enough juice to the motor.
#3 | |
ah that could make sense....
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
the washer fluid resevoir cap works well only if you make sure it **SNAPS** when you close it sucker seals tight.....if you just kinda flap it close and it clicks or something it will pop right back open....
I swear I've typed this before....deja-vu.....weird....I think I need to go to bed.... but nope the fluid won't come sloshing out.... most likely culprit was very small amounts of condensation forming in the fuel lines and causing a partial combustion event in the chambers ( I say this as the car was not run for what, two days, right?) |
#5 | |
yep not run for two days... and a lot of rain in the last two days.
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Problems starting the engine | fmicle | General Yaris / Vitz Discussion | 10 | 10-07-2009 08:48 AM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
| 90% on short trip. What to do to protect engine? | lh59 | DIY / Maintenance / Service | 22 | 12-17-2008 09:02 AM |
| higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 07:17 PM |
