Old 01-26-2009, 01:08 PM   #1
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
throttle response
can someone tell me or the throttle response is to chance through the OBDII connection. (I do not know if your cars have a electronic throttle but my Yaris have)
andries is offline   Reply With Quote
Old 01-26-2009, 04:02 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I noticed a center arm rest. How do you like it? Is it high enough? Where did you get it?
Old 01-27-2009, 11:20 AM   #3
andries
aka Jack Wolfskin
Drives: Yaris
Awesome
E-bay
Old 01-26-2009, 04:41 PM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yes. As far as I understand, the yaris has a DBW (drive by wire) throttle, which means that when I press the accelerator, it sends the value to the ECU first, and then the ECU sends it to the throttle.
There's a Blitz throttle controller out there that supposedly modifies the throttle curves and apparently works great if you want to get better response.
I went with lightweight NST pulleys, and the throttle response is awesome...
Old 01-26-2009, 06:45 PM   #5
NonStopTuning
NST Pulley Kit = MUCH better throttle response!
MIKE @ NST
www.NonStopTuning.com
Old 01-26-2009, 08:10 PM   #6
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
There is a Sprint Booster made by a Greek company. It plugs into the accelerator socket and thus modifies the signal from there.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 01-27-2009, 11:19 AM   #7
andries
aka Jack Wolfskin
Drives: Yaris
Thanks for the reactions.
I read the NST Pulleys are the best solution.
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
1zzfe throttle body lilman717 Performance Modifications 22 02-12-2009 07:08 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
10" Type R in TCAB - Freq response - vid spkrman In Car Entertainment + Electronics (audio / video / alarm) 3 03-20-2007 03:53 PM
