Old 09-25-2006, 09:24 PM   #1
IsLNdbOi
IsLNdbOi's Avatar
Change the DRLs?
Dunno if it's possible, but if I get fog lights installed, can I change it so the fog lights are the DRLs instead of the main headlights?
What would be needed for this?
Old 09-25-2006, 10:00 PM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
couldnt u just leave them on?
will work for parts
vodkalush is offline   Reply With Quote
Old 09-25-2006, 11:16 PM   #3
IsLNdbOi
IsLNdbOi's Avatar
Thanks, but that doesn't answer my question. I think if we did this, we could still have DRLs if we put HIDs in to replace our headlights.
Old 09-25-2006, 11:28 PM   #4
vodkalush
I drive a yarrrris
vodkalush's Avatar
I'm sorry, i didnt see where you goin where going with the question...*
couldnt you just re-route to drl "on" wires to go to the fogs, not the hls? I dont have the DRLs so I'm not sure how the wireing/box looks like....
I'll look the manual to see if the above can be done
will work for parts
Old 09-26-2006, 07:10 AM   #5
IsLNdbOi
IsLNdbOi's Avatar
Is this possible? Do you guys think it would be difficult to do this?
Old 09-26-2006, 08:28 AM   #6
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
In Canada spec, the fog light can only be turn on when you have the headlight turned on. But of course you can re-route the wires to have a different setup. You just have to find the wire diagram to work with.
GabL is offline   Reply With Quote
Old 09-26-2006, 11:50 AM   #7
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
A DRL works off of a dual filliment bulb, aka -high/low single bulb. The bulb is sent a lower current to light up the low beam end, and if you notice, is actually dimmer then if you had your low beams on.
Old 09-26-2006, 12:32 PM   #8
IsLNdbOi
IsLNdbOi's Avatar
And?
Not trying to be rude. Just don't understand what you're saying or trying to get at. Does that mean you can't use fog lights as DRLs? I've seen some cars that do that.
Old 09-27-2006, 01:27 PM   #9
Chris07LB
Chris07LB's Avatar
And?
Anything can be done with a little R&D. Have I tried? NO. Will I try? NO.
Old 09-27-2006, 04:23 PM   #10
IsLNdbOi
IsLNdbOi's Avatar
Well I wasn't asking if you were going to try it. What's with all the drama?
Old 09-26-2006, 12:42 PM   #11
vodkalush
I drive a yarrrris
vodkalush's Avatar
i think what hes saying is the DRl regulates the power to the HLs so it would be sending a power signal to weak to power the fog lights, or if not then they would simply be "dull"
there is always a risk of ruiniung a device by running the wrong power to it, under/over voltage/wattage.
atleast to my understanding.
will work for parts
Old 09-26-2006, 12:54 PM   #12
ChinoCharles
Drives: LB
Why wouldn't you just remove the DRL relay and leave your fogs on????????
Old 09-26-2006, 05:55 PM   #13
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
The signal shouldn't be too weak for fog bulbs, they are halogens, they'll light up. I think it can be done, it's just a matter of finding the right wires to swap around. It shouldn't matter that the headlights are Dual filament...
paultyler_82 is offline   Reply With Quote
Old 09-26-2006, 06:03 PM   #14
IsLNdbOi
IsLNdbOi's Avatar
That's what I was thinking. The bulbs I'm looking at using for my fog lights are PIAA's Extreme White H11 bulbs. They're supposedly 55/65w just like the headlights.
Old 09-26-2006, 06:43 PM   #15
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
Fog Lights? LOL I think we had fog once in Las Vegas in 1973.....
tomjasz is offline   Reply With Quote
Old 09-26-2006, 09:22 PM   #16
ChinoCharles
Drives: LB
HAHAHA
Old 09-26-2006, 10:37 PM   #17
IsLNdbOi
IsLNdbOi's Avatar
I'm gonna be moving to northern Cali in about two months. I'm gonna get HIDs retrofitted, but don't want to just disable the DRLs so I was thinking the fog lights could be used as the DRLs by simply connecting them to that DRL relay or box that Chris07LB had instructions about disabling.
Old 09-27-2006, 03:50 PM   #18
ChinoCharles
Drives: LB
Not even sure if the picture is applicable to the situation, but you have to admit... that shits hilarious.
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 08:15 PM
Dealership wants $64.99 for Oil Change? ScottFern DIY / Maintenance / Service 15 09-21-2006 10:49 AM
how to change front grille yaris lb? juanpaolo2006 DIY / Maintenance / Service 9 09-02-2006 08:47 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
