Old 12-25-2006, 08:17 PM   #1
03Z33
03Z33's Avatar
Drives: TCR10
Lightbulb Weight Savings
Seems like everyone is always after more power, more handling, and more braking. A great way to improve all of these for little to no cost is "weight savings". The benefits of removing weight from your car can be felt in acceleration, turns, and braking as well as helping the car save fuel, use less tires, and brakes.
Since the Yaris is my daily commuter and not a pure track car, I will be more conservative in stripping this car compared to my others Here is a list of things I've removed and kept track of as well as some planned changes.
Removed/Replaced:
(132) qty 4-15" stock steel wheels and tires 33lb each.
(24) stock steel spare wheel and tire.
(37) rear seat back rest
(11) rear seat lower bench
(6) rear seat bench steel support
(33) stock battery
(8) luggage tray/cover
(2) rear luggage and passenger carpets
(4) sun/privacy shade mechanism
(13) stock steering wheel with airbag
(20) qty 2 - stock front strut 10lb each
(10) qty 2 - stock front spring 5lb each
(6) qty 2 - stock rear shock 3lb each
(6) qty 2 - stock rear spring 3lb each
(9) stock rear rebar/crashbar
(24) stock axle back exhaust
(7) under seat jack and tool kit (track only)
(352) Total weight of removed/replaced parts
Added/Replaced:
104 qty 4 -15x7 Watanabe wheels and Bridgestone 195/55/15 tires 26lb each.
3 Nardi 330mm steering wheel with Works Bell hub and quick release
13 Odyssey PC680MJ battery
18 qty 2 - Cusco front coilover strut 9lb each
11 qty 2 - Cusco front spring 5.5lb each
6 qty 2 - Cusco rear shock 3lb each
8 qty 2 - Cusco rear spring and height adjuster 4lb each
5 C-One rear bumper bar
3 C-One rear strut brace
18 Tanabe Touring Medallion axle back exhaust
189lb Total added/replaced parts
163Lbs. = Total "weight savings" so far
According to Toyotas literature the manual hatchback weighs in at 2293lb wet. I haven't weighed mine yet, but will do so shortly when I install my new coilovers and corner weight the car, but according to the specs my car should now weigh approximately 2130lb. Many of my measurements are approximations and I welcome others to correct me if you feel I've made any errors.
I also plan to remove/replace/install the following parts which will change my numbers:
Bucket seats (hoping for 20lb combined savings for both)
C-One front sway bar (probably a couple pounds more than stock)
C-One front under brace (probably + 3-5lb)
front strut brace (probaby 2-3 lb)
Progress rear sway bar (probably + 10-15lb)
header (probably same as stock?)
aerokit with paint (probaby + 5-7lb)
JDM front rebar (~ 5-8lb less)
remove rear wiper and motor (~ 10-14lb less)
At this time I don't plan to remove the stereo, speakers, A/C, heater, interior, etc... But I may do so in future if I decide to take it further. If I do remove these items, any weight savings will be negated by the addition of a roll cage.
I'll do my best to continue to weigh stock and replacement parts as I continue to modify the car. Please feel free to add any comments or ideas as to where else weight can be saved
Old 12-25-2006, 10:13 PM   #2
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
has anyone seen people remove the rear seat and put some carpet in so it would look nicer mabye i just retarded
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 12-28-2006, 05:27 AM   #3
spkrman
Drives: 1
This is what I've done
It hink it was mentioned that it might be useful for storage space... thats exactly why I took em out :)
Good excuse to not cart people around too... "sorry you cant ride, no back seat"
Old 12-28-2006, 11:22 AM   #4
graywolf_14
Drives: um not a yaris but hopefully
yeah but...
Yeah but I have kids, they have never rode in my car but there is always the chance. Unless I can get someone to make tubular car seat holders that would be safe and lighter than the stock seats.
graywolf_14 is offline   Reply With Quote
Old 12-29-2006, 02:33 PM   #5
spkrman
Drives: 1
That would be interesting :)
A removable rear seat would also be feasable... or even the stock seat... its not that tough to snatch it out/put it back, but it doesnt exactly snap into place, and its awkword/heavy... but that heavy is what you want to remove anyway right? :)
Old 12-25-2006, 10:43 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
stock xA seats weigh 65lbs. i replaced with MOMO START and T-Frame and had aluminum brackets manufactured.
total savings... 90lbs :)
Old 12-25-2006, 10:50 PM   #7
03Z33
03Z33's Avatar
Drives: TCR10
Probably not a bad idea if you plan to store things and don't want them scratching up the interior. The stock carpeting only goes back as far as the rear bench, everything back is bare steel/paint.
Good news! I'm not sure that the Yaris seats are that heavy, I seem to remember someone saying they're actually pretty light, but I'll be swapping them out either way
Old 12-25-2006, 10:54 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
i would imagine you are correct, as they do sit much closer to the ground.
bracketry in aluminum tho, a little spendy, but they weigh in at only a couple pounds each :)
i've weighed in at 2150 with a full tank of gas, on my street wheels, (+maybe 10lbs)
the next 150lbs will be expensive lol
Old 12-25-2006, 11:01 PM   #9
03Z33
03Z33's Avatar
Drives: TCR10
It does get $$$ after this I actually had my eyes on the Ist since it first arrived here in the states. Came really close to purchasing more then once
Overall I'm pretty satisfied with the weight of these cars... I enjoy trying to get it down as much as I can though
Old 12-25-2006, 11:09 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
off topic but did you ever own a corolla? besides the GTS
Old 12-25-2006, 11:11 PM   #11
03Z33
03Z33's Avatar
Drives: TCR10
Nope... my only other FWD was a VW
Old 12-25-2006, 11:13 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
oh ok.. good good, thought i may know you from back in the corolla days lol
car looks good, any track footage?
Old 12-25-2006, 11:20 PM   #13
03Z33
03Z33's Avatar
Drives: TCR10
I'm usually to busy between prepping my cars, and jumping in and out of students cars... I wrote something up a while back on here:
http://www.yarisworld.com/forums/sho...ighlight=track
Now back on topic So who else has anymore ideas for weight savings? I'm not talking about little stuff like shift knobs and air freshners either
Old 12-26-2006, 03:47 PM   #14
Yarii
Drives: n/a
You could shave a few lbs with an aftermarket crank pulley and lightweight flywheel.
Yarii is offline   Reply With Quote
Old 12-25-2006, 11:27 PM   #15
I suppose if you wanted to be a little extreme you could lighten the doors, roof and frame by cutting out internal components like crash bars and so on. It would weaken the car, sure, but if you had a roll cage, it might be worth looking into?
Old 12-25-2006, 11:32 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
all the easy ones you've stated.. removing carpet and sound deadening sounds like a bit of savings there.. from below the center of gravity, but weight nonetheless..
i'd like to see swapped door-cards on my car in the near future. once i get my new (1988 toyota pickup 1 ton long bed) daily driver i'll be a little more frisky with the mods to the xA
Old 12-25-2006, 11:41 PM   #17
03Z33
03Z33's Avatar
Drives: TCR10
Yeah, there's probably a few pounds in rear door beams which I wouldn't mind removing since I'll never have passengers back there... The fronts I think I'll leave in for now, at least until I get a cage.
I actually checked out the Tein Yaris which is pretty well gutted, and it doesn't seem that there is too much to remove... the floor did look nice and shiny without any carpeting though
Old 12-26-2006, 01:10 AM   #18
501
Drives: 07 yaris
i need to lose wieght myself maybe 10-20lbs
'07 blazing blue hatch-TRD shocks-tanabae df210-TRD rear sway bar-koning feathers 16x7-the basics for now
501 is offline   Reply With Quote
Yaris Curb Weight, difference LB vs Sedan CASTREX General Yaris / Vitz Discussion 14 12-12-2006 09:50 AM
15" alloys weight? obylium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-25-2006 12:05 AM
Stock 15" RS 5 Spoke Rim weight? GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-03-2006 05:23 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
KONIG HELIUM Ultra LIght Weight wheels C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 08-03-2006 06:00 AM
