Give Me Resonance
My idea and your thoughts about it.
Heres the quick & dirty.
The back end of my hatch sags low, too low. The reason for this is of course all the car audio equipment. I intend on adding more to the back end so my question to you guys is what route should I go and which which work best. I want there to be minimal wheel gap but if it means saving money then I can deal with it. Should I either put 2 of my stock springs back in for the rear or should I try and get a hold of 2 NF210's? ![]() ![]()
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver Last edited by The Architect; 02-09-2009 at 06:39 PM. |
I'd just go with a set of stock springs.
get rear springs from an xB. designed to hold more weight. same top/bottom
I'd get air shocks, or use a set of spring rubbers. If you need a set of spring rubbers, I've got some.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
#5 | |
Apexing Egg!!
http://www.racingplus.com/coil-over-...ber/1343p10255 here are some for sale, different strengths...
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
Top Notch!
Coilovers. That way you can be low, and the ride will be firm.
I don't think you should consider going for NF210's since they won't give you more than 0.5" of extra space. I think you should try going back to stock springs in the rear (at least you can give it a shot for free).
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
