Old 09-03-2007, 07:37 PM   #1
hari
Drives: 2008 Red 2dr Yaris Hatchback
? Rota RB 13x8
Hi,
I have less than 2 days to decide if I will purchase them.
Need to know if a lowered Yaris liftback will have any rubbing issues with these kind of rims installed.
Rota RB 13"x8"
Thanks.
hari is offline   Reply With Quote
Old 09-03-2007, 08:03 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Originally Posted by hari View Post
Hi,
Rota RB 13"x8"
Thanks.
I'm looking at these also I really like them ,especially in the small size, but the offset is +4 .These wil stick out from the car like mad.
SPONSORED BY
Old 09-03-2007, 10:23 PM   #3
Lafiro
Drives: 06 Yaris Sedan
+4 ??
If I'm right, they will stick out like mad.
Old 09-03-2007, 10:50 PM   #4
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Yes, +4. These are intended for RWD vehicles such as AE86s and British sports cars and stuff.
Old 09-04-2007, 12:13 AM   #5
brickhardmeat
Lonesome Cowboy
you could get a staggered set of 15X7 up front and 15X8 in the rear, I was thinking about doing that a little later
SPONSORED BY
Old 09-04-2007, 12:14 AM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
Those wheels are beautiful! Unfortunately, 8's, ET+4 will never work on a Yaris. Too bad.
Old 09-04-2007, 12:17 AM   #7
brickhardmeat
Lonesome Cowboy
you could do it but the wheels would stick out far from the fenders, it would look really bad up front, I wish the would do these 13X8 in a +30 or +35
SPONSORED BY
Old 09-04-2007, 12:32 AM   #8
kimona
kimona's Avatar
Even a 13x8, ET 30 to 35 would still stick out too far.
Old 09-04-2007, 12:53 AM   #9
kimona
kimona's Avatar
BTW, if you really like that design wheel, you could probably get it in the original Panasport in 13" through 16" with the proper offset and with many colour options.
I presume you realize that if you plan to run 13's as daily drivers, then finding performance tires for the street will be somewhere between extremely difficult and absolutely impossible. On the other hand, rubber for the track will be easier to come by. Furthermore, 13" rubber is too short for your Yaris as a daily driver.
Old 09-04-2007, 01:15 AM   #10
kimona
kimona's Avatar
Buywheelstoday.com
American Racing 15x7, ET42; Konig Rewind 15x7, ET40
Old 09-04-2007, 09:24 AM   #11
brickhardmeat
Lonesome Cowboy
there are several tire companies with 205/60/13 and that is not too short for a daily driver, less rolling diameter, yes, but too short, huh? no it's not
also we're talking everyday tires-federal and cooper and toya all make 'em
SPONSORED BY
Old 09-04-2007, 12:17 PM   #12
kimona
kimona's Avatar
Well, good luck finding a quality performance street tire in that size these days. Not easy to come by.
And, 205/60/13's are 1" shorter than OEM's and are not recommended as daily drivers. Period.
Furthermore, if you lower the car with Tiens, you'll be too low for comfort... even speed bumps will give you a problem!
But... have it your way.
Old 09-05-2007, 04:11 AM   #13
loafer650
loafer650's Avatar
Drives: 07 yaris sedan
8's on a yari without a widebody kit would look like ass imho....
loafer650 is offline   Reply With Quote
Old 02-11-2009, 01:13 PM   #14
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
I'm looking at the Panasports 13 x 8's I plan on using 225 x 45 x 13 R888's for the track.
What offset would work best?
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 02-11-2009, 02:34 PM   #15
Nagoya_TRD.
Drives: None.
Best way is to measure up and check.
Tie a bolt to a string, and hang it from the farthest point on the fender (tape it on). Hub is 0 offset (in the middle of the 2 "J" ends of the wheel). Then use a ruler to measure out how many MM the bolt hangs from the hub. Then measure how much backspacing you have.
Depending on how much lip, and how low you want to go , you can measure out how wide of a wheel and what kind of offset you want. Also if you want to roll and pull your fenders.
8 inch wide and a +4 is doable on a yaris (if you measure it out and it doesn't fit, then i am wrong), but i think it's just really aggressive, depends on your style really.
Nagoya_TRD. is offline   Reply With Quote
Old 02-11-2009, 07:37 PM   #16
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Im not even sure a 13" wheel would clear the front calipers.
Saggio is offline   Reply With Quote
Old 02-11-2009, 08:14 PM   #17
toad
toad's Avatar
Drives: street-legal go-kart
a few guys(pre-hack) were running lenso vpd's in 13". they did barely clear the front calipers, but it is do-able(with that wheel anyways). you're gonna have to drop it pretty low to look decent and like kimona said 'speed bumps will give you problems'. tire rack sells a 205/60/13 sumitomo pretty cheap too. i believe the offset on the vpd's is +25, 13x7.5. i've been looking at this setup pretty seriously now that tax refund time is near! they are listed as 'competition only' and will look smallish on our car, but there's just 'something' i like about that look(and weight savings too!). :)
toad is offline   Reply With Quote
Old 02-11-2009, 08:26 PM   #18
old thread, but dang, loving those panasports.
Here is the brake/caliper fitmnet guide:
http://www.panasport.com/PANASPORT%20Worksheet-Disc.pdf
Rota RB or Koniq Rewind..? seanele Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 04-28-2010 01:48 PM
Cont: Rota GT3 elsteverino889 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 08-11-2007 11:33 AM
Anyone running SSR Type X or Rota Auto-X wheels? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 08-06-2007 04:00 AM
rota 15's...what do you guys think? SamDaYarisMan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 05-13-2007 11:30 PM
18 Rota Torques? nebulight Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-12-2007 10:32 PM
