Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Australia
Old 11-20-2008, 02:10 AM   #1
k3nn4
Drives: Yaris Sedan
HID Lights Install ?
Guys, Just wondering where can I install my HID Light Kits in Perth?
Thanks
k3nn4 is offline   Reply With Quote
Old 11-20-2008, 02:17 AM   #2
If it's a simple plug-and-play, you can do it yourself. It's pretty easy and self-explanatory.
Old 11-20-2008, 02:51 AM   #3
k3nn4
Drives: Yaris Sedan
Doesn't need to wiring ???
I'm thinking to buy this from ebay
http://cgi.ebay.com.au/MARS-BluePack...742.m153.l1262
Old 11-20-2008, 02:55 AM   #4
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
it's h4 bi xenon bulb right?
darkmoon87 is offline   Reply With Quote
Old 11-20-2008, 02:55 AM   #5
k3nn4
Drives: Yaris Sedan
Yupe it's H4 bi xenon :)
Old 11-20-2008, 03:01 AM   #6
Nope, doesn't seem like it needs anything else. However, contact the seller to make sure. But again, it looks like it includes everything you need. I like how it uses Philips bulbs. You shouldn't have a problem with that. However, I don't know where the ballast is manufactured. I'm betting that that kit is better than the HID kit I have.
Old 11-20-2008, 03:14 AM   #7
k3nn4
Drives: Yaris Sedan
Thanks for the information :) I will ask the seller and see if it come with the installation manual or something
Old 11-20-2008, 03:22 AM   #8
If it doesn't come with an installation manual, let us know. It's pretty simple, plug the lead into the ballast (doesn't matter which way with an H4, meaning + to + or + to -, I had to invert mine to + to - to get it to work), then plug the other cables to it's proper mate (mine were a 6000k cable and a high beam cable, I believe), then plug in the 3-prong connector to the car's socket (you know, the socket that a regular bulb plugs into).
The only hard part would be getting the bulb into the rubber plug/sleeve. I had to cut mine to put it through. Now I get condensation in my headlights every now and then.
Old 11-20-2008, 03:30 AM   #9
Yeah, you should do that for the OP. Too late for me. LOL.
Old 11-20-2008, 03:41 AM   #10
lunjiaow
lunjiaow's Avatar
Drives: Yaris
Where did you get the kit from?
Looking for HIDs...
lunjiaow is offline   Reply With Quote
Old 11-20-2008, 04:09 AM   #11
k3nn4
Drives: Yaris Sedan
Looking for HIDs...
I think you should read all over my post again -.-''
eBay the answer
Old 11-20-2008, 08:36 AM   #12
lunjiaow
lunjiaow's Avatar
Drives: Yaris
oops my bad.... looks pleasing.
You could hide the ballast under the headlights, thats what i did for my other cars.
Makes it stock looking, and if the cops pull you over they wont be able to spot it to give you a yellow.
Old 01-20-2009, 11:41 AM   #13
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
our car has reverse grounding system.. hope its plug and play otherwise you may need to switch some wires..
Old 01-24-2009, 07:55 PM   #14
bimmerman86
Drives: 09 Corolla
Ok, my friend reversed the wires to get the lights to work. Problem is that they flicker and don't stay on. The only way to get the HIDs to stay on is if he runs them as high beams, but then the halogen bulb has no function. Can someone explain to me how to reposition the wires to get the HIDs to function as low beam and the halogen as high beams? I feel bad getting him the kit and not be able to help him to rsolve the problem. I want to at least get him good info.
bimmerman86 is offline   Reply With Quote
Old 01-25-2009, 11:13 AM   #15
marcus
toyota
marcus's Avatar
drl is causing the flicker for low beam you either take the drl relay of or or relay the low beam instead . that relay and fuse should come with the hid kit..
Old 01-25-2009, 06:34 PM   #16
bimmerman86
Drives: 09 Corolla
He says his car doesn't have DRL.
Old 01-26-2009, 11:06 AM   #17
marcus
toyota
marcus's Avatar
uhmm as far as i know all yaris has day time running light DRL.... thats the only reason why its flickering.. drl run on 10 volts where hid needs 12 v at least otherwise itll flicker. ..
relay low beam..although it may be on the whole time you can always use high beam on day time..
Old 01-26-2009, 08:09 AM   #18
Masteraal
Masteraal's Avatar
Drives: Black Yaris YRS 3dr Manual
k3nn4 takes some pics for me i was looking at the bluepack too :) thanks mate
Masteraal is offline   Reply With Quote
JDM modelista tail lights install/ photoshoot yrsdrgn Photo-Video-Media Gallery 24 08-20-2007 04:00 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Experts: Should I, a newbie, install HID lights? iconcat Cosmetic Modifications (Exterior/Interior) 16 06-01-2007 07:52 AM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 10:47 PM
