Old 02-13-2009, 05:36 AM   #1
helphelp911
Drives: yaris
Mod for smooth ride?
Any mod can smooth the ride?
thanks
helphelp911 is offline   Reply With Quote
Old 02-13-2009, 05:44 AM   #2
ddongbap
Add extra weight.
Old 02-13-2009, 03:46 PM   #3
supmet
Drives: 2007 4 Door Yaris
aside from slightly wider tires and upgrading your suspension, the TRD sway bar makes the car feel much more responsive and roll less on turns. My yaris also feels more stable on the freeway.
Old 02-13-2009, 04:42 PM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Need more input.
New Yaris? Old Yaris? How many miles? Might just need new shocks.
What sort of "not smoothness" is bothering you? Bumps? Railroad tracks? Washboard roads?
What tires do you have on the car (size, model and brand) and what pressure do you have them inflated to?
Old 02-13-2009, 10:35 PM   #5
helphelp911
Drives: yaris
Originally Posted by Loren View Post
Need more input.
I have 07 42000km base 14" stock yaris. Tires is 35psi. i have it for few weeks. No mod yet.
i used to drive bigger car, x5. When i switch to yaris, i keep feeling my body keep pushing around, shaking. i considered the rear sway bar before but i heard ppl said it actually made the ride more rough. i only want to make the ride more stable.
Thanks for the input.
Old 02-13-2009, 10:58 PM   #6
supmet
I wouldn't call the ride more rough at all, perhaps more sporty. It keeps the back tires on the ground a little more, so you do feel the road a little bit more, but I think it is more than worth it to keep the body from rolling every which way.
"When i switch to yaris, i keep feeling my body keep pushing around"
^^ That is EXACTLY what the rear sway bar prevents.
Old 02-13-2009, 11:23 PM   #7
helphelp911
Drives: yaris
Thanks, i will go for sway bar then.
Old 02-14-2009, 10:00 AM   #8
Loren
What?
Loren's Avatar
Yeah. You need to properly describe the problem to get the correct answer. If the ride is rough (which... compared to something like a big Lexus, it is), there really isn't much you can do about it besides fit tires that have softer sidewalls to absorb more road imperfections and make the ride smoother.
If you're feeling too much body sway, like from cross-winds and such, then the rear swaybar will definitely help. But, that's not adding "smoothness", that's adding "stability".
Upgrading to more performance-oriented 15" tires (or even better 14" tires to a lesser degree) will also help with stability.
You might try raising your tire pressures a bit. 35-38 is about right, but some people run 40-45. That will improve steering response and eliminate most of the "give" in the tire. Will definitely make the ride LESS smooth (the tires will transmit every little bump in the road), but somewhat more stable.
Stiffer suspension - same ride height? fuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-13-2009 07:53 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
Final Got My 2ND Mod For My Yaris! pp.sweet DIY / Maintenance / Service 10 09-24-2007 02:52 PM
ait resistor mod pigpenracing Performance Modifications 24 08-25-2007 11:14 AM
My Ride.... digital_strings Photo-Video-Media Gallery 13 05-19-2007 09:02 AM
