Roar?
manual trans fluid
did a search for 2 hours didnt find the weight i need... i am sqitching to amsoil trans fluid and correct me if i am wrong but it is 2 quarts right?
Roar?
please???
![]() ![]() Drives: 07 BB Yaris Join Date: Aug 2007
It should be in your manual, homie. You can also find a .pdf copy of the owners manual at http://www.etimago.com/yaris/repairmanual/
Manual Transaxle Oil type: API GL-4 or GL-5 75W-90 2 quarts or 1.9 Liters |
![]() ![]() ![]() ![]() Drives: 07 Yaris LB Absolute RED Join Date: Apr 2007
hey x what part of mass you from?
v |
Taunton, I go to school in Boston though... but I am on break right now
![]() ![]() ![]() Drives: 07' Yaris Liftback - silver Join Date: May 2006
Im in Spfld MA!! NQD + MASS FTW!!
der Zeck
I want to switch my fluid as well, but I feel dumb, and do not know where to fill it back up at..... it is the only reason why I have not done it yet
![]() Drives: 07' Liftback, man., Bayou Blue Join Date: Sep 2006
fill hole
Black Yaris:
The fill hole can easily be seen standing in front of the car and looking down in the engine compartment to the right (driver side) of the engine. On mine, both the drain and the fill hole have a while adhesive tag on them. I, too, plan to change to Amsoil 75W90 synthetic. |
#9 | |
der Zeck
![]() ![]() ![]() ![]() ![]() Drives: 07 Bayou Blue Liftback Join Date: Apr 2007
I am trying to get you guys a screen shot, but the putter is not behaving. Just go to the manual sticky (C50 Manual Transaxle, P 12) for the filler and drain plug location. It does not make a lot of sense until you visually inspect the vehicle in comparison to the diagram. You can use a funnel with a long hose to fill it from the top.
YES, I finally got the dam thing to work! |
BTW, here are a few more specs that I scrounged up which covers most often maintained items.
2007 TOYOTA YARIS 1.5L 4-cyl Engine Code 1NZ-FE FILTERS Oil Filter........ EAO09 AMSOIL Ea Oil Filter Oil Filter........ 51394 WIX 51394 Oil Filter Air Filter........ 49104 TRICO WIPER BLADES Driver: NEOFORM (T16260) EXACT FIT (T261) WINTER (T37260) OKTANE (24) Passenger: EXACT FIT (T141) WINTER (T37131) LUBRICANTS & FLUIDS Engine Oil Grade 1......API* Series 2000 Synthetic 0W-30 Motor Oil SAE 5W-30 Synthetic Motor Oil SAE 5W-30 XL Synthetic Motor Oil Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil All Temps......5W-30 Manual Transmission,.....GL-5 All TEMPS......75W-90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube Manual Transmission,.....GL-4 All TEMPS......75W-90 Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 Automatic Transmission.....WS Fluids Brake Fluid.....HB Clutch Fluid.....HB CHASSIS LUBRICATION 0 Fittings, 0 Plugs CAPACITIES Engine, with filter..........3.9 quarts[1] Cooling System, W/ MT Initial Fill..........5.1 quarts Cooling System, W/ AT Initial Fill..........5.0 quarts Automatic Transmission, Initial Fill..........2.7 quarts[2] Automatic Transmission, Total Fill U340E..........3.1 quarts Manual Transmission, ..........4.0 pints 1. After refill check oil level. 2. With ENG at operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed. TORQUES Oil Drain Plug.....28 ft-lbs Manual Transmission Fill Plug.....29 ft-lbs Drain Plug.....29 ft-lbs |
#12 | |
der Zeck
![]() ![]() ![]() Drives: 2006 Yaris Join Date: Dec 2006
Thank you blacksan, very useful information.
It's a red yaris
Hmmm, I need to double check as I did not notice a drain plug on my pan??? On my last Toy truck I also had duel drains and no one else with the same setup did???
der Zeck
I seem to remember Chino calling me the first time he changed his oil asking me which drain plug he needed to pull..... so I know I am not the only one..... or it is just an Ohio Yaris thing
Ok, mine also has duel plugs. I made a few calls and was told that pulling the pan plug (lowest point) is sufficient after heating up trans. I drained via vacum pump and did not bother with the drain plug as it was at only 5K.
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
It must be the new manual trannys, but in all the manuals I've ever done, I just used a normal motor oil like Mobil-1 10W-30. They all shifted like a dream! 75W-90 is some thick stuff. I wonder why it needs to be so thick?
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
| Manual Yaris performance info? | SimmZ | General Yaris / Vitz Discussion | 22 | 10-27-2009 10:27 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 05:25 PM |
| The Toyota Authorized Repair Manual. | LoudYar | General Yaris / Vitz Discussion | 3 | 03-29-2007 01:20 AM |
| 2007 LB Yaris - AT - Fluid Change Interval | Pavel Olavich | DIY / Maintenance / Service | 9 | 03-21-2007 07:09 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 11:57 PM |
