Old 05-07-2009, 04:49 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Sedan Door Panel Deadening
I have many more pictured than what is actually shown here. This should give anyone who wants a look inside the door of a sedan a pretty darned good idea of what to expect with a proper deadening of the door.
My my...this looks like a door:
The power controls removed. It is just one screw and the removal of the control panel:
The sail panel removed:
The door skin off, with the handle screw, the pop pin right below the sail panel removed, and the moisture barrier tossed:
Laying down deadening on the outer door skin:
A Dynasorb panel added behind the stock speaker:
Building a base to put the deadeing over, it's initially placed with hot glue and then silicone:
Deadening of inner door skin:
I put a second layer on the bigger "open" areas that have the reinforcement under it:
1/4" of Ensolite roughly cut to fit the door:
This is GREAT contact glue:
The Ensolite on the door panel:
Here's the lock and handle lines wrapped in Ensolite...juuuust in case:
After the Ensolite was put on, I trimmed it up a little bit. The inside door panel had some styrofoam that I removed. I put more deadening on the panel itself. When I get some time I'll take some corrugated egg crate foam and hit the rear bottom of the panel for my own satisfaction.
The door panel already had a nice solid sound when it closed...now, it's a very satisfying, weighty sound. I'll kick up another posting when I do the trunk and the floor pan. It's going to be a few months before the Hybrid Audio L841-3 set goes in. Of course, the pictures will follow with that. The alarm comes first...It's a nice little AutoPage RS-1000. That happens next month. No pictures on that, sorry!
― Thomas Paine
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 11:28 PM
Toyota Australia releases YRX SEDAN. Sp33dY General Yaris / Vitz Discussion 1 08-01-2006 02:19 AM
