it's been a while
HELP!! spring install help again lol
okay so i'm trying to do the fronts and i cant seem to hold the allen key without it moving while i try to unscrew the nut, do you guys have any suggestions or tips? thanks!
#2 | ||
Start another Oil Thread!
that, or use an impact gun
you nailed it sir.
#3 | |
it's been a while
#4 | ||
did you look at the sockets? they're hollow you can put your allen key thru the middle of this and hold it with pliers or something.. i dunno that or get an impact gun :)
you nailed it sir.
#5 | |
it's been a while
i have the 17mm offset wrench like in the diy, maybe i'm not using enough strength! |
If you haven't busted your knuckles yet and lost some blood....your not doing it right.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
it's been a while
it turns the normal way. Right to tighten, left to loosen.
You have to give it some effort, maybe yours is stuck. Spray it with WD40 and walk away from it for 10 minutes. Mine took half the skin off my hand I was so cut up from it.
#9 | |
it's been a while
i just got it off! whooop
Congrats. The rest is easy.
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Good job.
For future reference, an impact wrench makes this about a hundred times easier. |
#12 | |
Top Notch!
The rears you can use an impact wrench, but not the front. Unless there is access to the strut with the whole wiper cowl removes which I haven't done on these cars yet. |
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
yup, whole wiper cowl remove!
#14 | |
i've never attempted removing the struts without pulling the wiper cowl.. and i don't think i ever will..
after all it's only like 12 10mm bolts lol
you nailed it sir.
it's been a while
Well guys I finished finally :)
thanks for your help i'll post some pictures later after i rest, i have a killer headache and i'm tired haha |
![]() ![]() ![]() ![]() Drives: 07 metmet LB Join Date: Oct 2008
for future reference...if you offest the allen so it pins itself up against the side of the cowl or whatever is adjacent to the bolt, it will wedge itself in and you wont have to hold it. Thats what i did.
F5 CAI, MR axleback, MR Header, NST SSK. Full Exhaust wrap, AT3 Custom SSK Konig Heliums 15x6.5 Black Tanabe Df210's |
| Spring install help | jinxor | Australia | 14 | 04-23-2009 11:17 AM |
| TRD Spring Install Labor Costs | XYaris | Performance Modifications | 10 | 01-26-2009 10:39 PM |
| Suspension install: Spring Compressors? | Thirty-Nine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 09-18-2007 11:59 PM |
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 10:26 PM |
| Spring Install Price | redglare45 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-30-2006 09:32 PM |
