![]() Drives: 2009 yaris Join Date: Jun 2016
auto trans rpm lowering for mpg
what options do auto trans owners have to lower final drive rpm to increase mpg in second gen yaris?
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
Are there any except for driving slower or having different gearing?
I'm a hermit named Lee |
Like Leegamer says, "drive slower". You could drop the rpm marginally by installing larger tires, but then you'd be using more power to turn them, negating any fuel economy gains. Do you not already get excellent fuel economy? I have the auto in one of my Yari and fuel economy is exceptional. I haven't actually compared the rpm at say 110 kmh between my auto and manual. I should do that.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
larger tires. Trailer tires are taller, 195/65r15s are taller.
Have you considered alternative approaches, like adjusting your driving habits, or are you specifically looking for modifications to the car itself to improve fuel efficiency?
For those who have made modifications, how significant were the changes in fuel efficiency, and would you recommend them to other auto trans owners seeking better MPG? |
Have you explored other options, such as adjusting your driving habits, or are you primarily interested in car modifications to enhance fuel efficiency? If modifications were made by others, how impactful were the changes in fuel efficiency, and would you suggest them to fellow auto transmission owners aiming for better MPG?
| what to look out for when installing lowering springs | songa | Performance Modifications | 34 | 09-15-2012 03:29 AM |
| Reluctant upshift to 3rd while cold (auto trans) | pauljk | General Yaris / Vitz Discussion | 40 | 01-22-2011 06:04 AM |
| Effects of too much trans fluid in the case? (auto trans) | detroiter | General Yaris / Vitz Discussion | 5 | 02-24-2009 11:08 PM |
| What RPM's are you americans getting on Auto trans? | BMGYaris | General Yaris / Vitz Discussion | 12 | 11-02-2006 02:43 AM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
