![]() Drives: VITZ 2005 1,000CC Join Date: Feb 2009
where is the ENgine Number?
Guyz i would like to know where is the engine number located. I have a 2005 vitz Japanese. i need to know the engine number for registration purpose. Thank You.
SIPNDEW
i wanna say in the door jam on the info tags...but im probably wrong.
under the hood you'll see a yellow sticker with info about the engine. the code will be on that sticker
http://en.wikipedia.org/wiki/Toyota_SZ_engine#1SZ-FE
SIPNDEW
that tag has the ESN on it or is it just the Engine Code?
it's usually a vacuum diagram and will say the engine code. depends.. either way it's a 1szfe engine
SIPNDEW
ah, well i think he may want the engine serial number, not the engine code. but ill let the user tell us. :) some places have to register the ESN for theft recovery, not us though.
Tamago, whats with the 6mm red line anyhow? I would love 6mm wider fenders. haha |
#7 | |
and it's a kind-of parody.. the red line.. it won't be my sig for long :)
SIPNDEW
haha, cool. well im gonna drive down there and you can make my fenders 6mm wider if you want...to get rid of my rubbage issue. :)
#9 | |
-1deg of camber will give you approx 5.3mm of outer sidewall-to-fender clearance on a 205-55-15
@mike
yes I need the ENGINE SERIAL NUMBER. come on guyz help me out here. its not in the doors n there is no yellow sticker either. its a Japanese model. I believe in you guyz. You guyz can do it. LOL. |
it's between cyl1 and cyl 2, on the block, just below the head, front side of the engine, behind the intake manifold. you'll need a mirror or an orthoscope
@tamago
i have a steel engine sheet covering that area in front of the engine. and right behind are the intake manifold. i did not see any more. on the engine i can see 1-KR its on the right front upper side of the engine. but that is engine type no good for me. |
Beast
not sure on this... cant you check it in the vin?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#14 |
the actual serial number of the engine is what he needs.. if the engine has been swapped out the vin and SN wouldn't match
OP, sorry, best guess i could give!
#15 |
this is a Japanese model vitz imported form japan there is no vin number. thanks guyz for all your help.
#16 |
it has to have a vin.
#17 |
SIPNDEW
if the vin plates were removed...try moving the passenger seat all the way back, look at the floor, if you see a plastic cover the open it up and the vin is under that as well. with the vin you can call the dealer and they can get you the ESN, but you said its imported so you may have to have someone do it for you..IE whoever imported the car.
#18 |
it's also STAMPED to the firewall behind the wiper tray
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| FS: Used Beatrush Engine Roll Stopper | FunctionSpec | Items for Sale by private party | 7 | 06-02-2010 01:38 PM |
| engine swap update | Adriaan | Canada | 5 | 03-03-2009 06:21 PM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 12:51 AM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
