Old 02-28-2009, 02:02 AM   #1
silver_echo
ekodrvr
silver_echo's Avatar
whistle?
anyone else notice the slight whistle from the intake manifold? normal? i think that it is normal as i have heard it on other echos that i see as well as 1st gen xBs and xAs... very low on gas pedal pressure, usually low in RPM almost sounds like a vacuum leak, but no codes, and it only sounds at a specific pedal point...
silver_echo is offline   Reply With Quote
Old 02-28-2009, 02:24 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
it's a common noise, usually louder when you have an intake.
Old 02-28-2009, 02:53 AM   #3
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Just in case, check for holes or breaks in the rubber/plastic.
Old 02-28-2009, 02:56 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
you'd have a CEL if there were leaks between MAF and engine.
Old 02-28-2009, 03:16 AM   #5
rningonfumes
Not necessarily, had the rubber on my Camry's 4cylinder go bad, took me a week realize the NEW (lol) whoosing/wheezing sound was a tear-- no CEL. Then again the Yaris is newer, you could be right.
Doesn't hurt to look, does it?
For the record, I don't hear any sound from my stock unit.
Old 02-28-2009, 03:18 AM   #6
silver_echo
ekodrvr
actually mine is an 01 echo... same car, same motor, and has been doing it since i got into it with 10k miles just never really bothered with it... i think it has something to do with the fact that the intake manifold is plastic
Old 02-28-2009, 03:23 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
same engine block, but very very many differences between the yaris 1nz and our (echo and xa/xb) 1nz... learning more differences every day :(
Old 02-28-2009, 03:18 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
he's an echo
shares ECU(kinda) and throttle body with me. y'all are DBW and use a different MAF etc.
Old 02-28-2009, 03:19 AM   #9
silver_echo
ekodrvr
have to say it, HAHA i typed faster!...
Old 02-28-2009, 03:25 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
3:18 > 3:18 :(
Old 02-28-2009, 03:32 AM   #11
silver_echo
ekodrvr
aren't they all the 1nz-fe? should be the same all the way across, and it looks like the same manifold one the yar
