Strut Bar Advice.
Hey everyone,
I'm considering getting some front and rear strut bars for the Yaris. I'm interested to hear your comments on these questions:- Is there a performance difference between a strut that goes under the car (under engine or under hatch) vs one that goes on top (engine bay or hatch) Are all strut bars created equal, is there any real difference between the expensive and cheap ones? What would you recommend in front and rear strut bars and why do you recommend that particular brand? At this stage i'm thinking of getting underbody bars as i like to be able to fold my 60/40 back seats down to put things in the back, so the cross brace in the back is a no. Looking forward to your comments.
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
![]() Drives: 07 Yaris, 4dr Daily Driver Join Date: Aug 2007
there is minimal performance gain when adding bracing bars. There should be no difference in the material quality of the pieces, but a good design is essential to proper chassis stiffening. The point of the bars is to make the chassis bend less during hard turns. If you notice when cornering the car seems to feel as if it is going to tip over, thas the body roll and the more bars you add the less the car will feel that way. I would think of it as adding bars to the top and bottom of the engine to turn the frame into a cube that is more solid. Adding bars on the bottom/top of engine only would give you less performance than putting a front under brace, and a front strut tower brace on at once.
as far as which one to get_ a bar that rests on three points is better than two, and usually the simplest design is the most effective.
Live, Life, Lavishly! |
Slowy getting there
I'm looking to get some bracing bars and have been reading up on them. For the bars that go under your car I would go with the GT spec braces. As for the bars that are on the top almost any of the (engine bay) front ones are good. Now for the for the rear you can get one if you like but be perpared to get bashed by user Tamago because the rear of our car doesn't have struts and the way the bar bolts on to the car it sits on the shocks with the rubber bushings so having no real support
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
I've read that a rear sway bar for the Yaris is a good effective mod..
You have choices from Whiteline (Shelby), Ultra Racing, and TRD (USA)..
Slowy getting there
Oh yea sorry forgot to add that one. While I'm adding GT Spec makes a rear lower strut bar too don't think I have read about anyone installing one.
Ultra Racing is as good or better than GT Spec for less money. I've used both.
The only two braces to start with are rear sway bar (which isn't a brace), and the front strut brace. Other than that, I'll stay out of the "do they do anything, or not" discussion.
#7 | |
Thanks Garm
since you don't have struts in the rear.. i don't recommend wasting money on the spaghetti bar.. get the other X bar if you want something that actually stiffens
this is functional: ![]() this is for looks:
#9 | |
ok thanks, yes i skimmed what you typed
if you don't legitimately race the car i don't see the point of installing braces personally.... unless it wins you points at car shows ;)
So in your opinion i'd be better off spending that money on springs instead? I'm never going to race my Yaris. I think stock springs are too soft.
#12 | |
get the car lower first.. swaybar is a must.. skip the braces unless you have extra money to throw away then again i'm in "saving" mode right now so i see almost ALL mods as useless.. .
What swaybar do you recommend and why?
cannot comment, don't personally have a yaris.
i have a progress bar, it's a nice piece.
rarer than JDM -1 of 1!
Get a quick-release tab for your car, and you can remove the rear STB whenever easily!
What kind of car is that?
the rear tower strut does have an effect at high speed bends
all the weight is thrown to the rear end the brace will do more but the strut tower isnt just for looks under the car sway bars do more than the strut but less then the cross brace
explain how it works please
| Tanabe Front Strut Bar | Benggolf2 | Performance Modifications | 57 | 08-15-2014 02:41 AM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| Do you HAVE to remove the wheels to install strut bar? | Yawesh | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 02-10-2009 02:35 PM |
| Installed the Tanabe Strut bar but had to remove my ground wire kit.. | vacantj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-01-2007 01:56 PM |
