hook em
adjustable camber bolts....
anyone installed them?? bot some but came with no instructions...
You remove the old bolt and install the new one? Wouldnt you be having a alignment shop be doing this since they would be the ones adjusting the camber.
remove wheel, undo stock bolts, replace with crash bolts, push the top of the assembly in and pull the bottom of the strut assembly out - voila!
put the wheels back on and then promptly take it to an alignment shop so they can adjust toe in closer to neutral...
#5 | |
Start another Oil Thread!
obvious answer is obvious!
you nailed it sir.
| Tighten bolts to factory specs? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 10-19-2010 06:18 PM |
| Gauging Interest: Whiteline Front/Back Adjustable Sway Bars | RaptorRacing | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 12-15-2009 05:23 AM |
| Adjustable Camber Bolts | cali yaris | Micro Image | 30 | 12-11-2009 10:38 AM |
| Are camber bolts needed after installing springs? | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-01-2009 01:19 AM |
| Who makes camber bolts? | largeorangefont | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 07-08-2007 01:22 AM |
