Old 03-12-2009, 11:53 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Hot engine bay
I think i have a leak by my header. The bay is kinda hotter than usual and my car doesnt pull hard anymore. I tried to listen for a leak sound but there are just too many noises for me to tell. i tighten the bolts but to no avail. Idk.... i neeed to dyno this thing once and for all...
Yoda is offline   Reply With Quote
Old 03-13-2009, 12:04 AM   #2
06silveryaris
Drives: 2006 yaris
check for the exhaust leak when the car is cold and under load that is when it will make a more noticeble sound. you can also try thermal wrap for you exhaust manifold, that ill help wit the temp issue in the engine bay
06silveryaris is offline   Reply With Quote
Old 03-13-2009, 02:26 AM   #3
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
as far as heat in the engine bay, that happens with the introduction of headers or turbos on stock econoboxes...the weapons in your arsenal are dozens of differant ceramic and other types of temp coatings, and thermal wrap.
thermal wrap looks horrid, but you can build a aluminum heat shield to cover the nasty look and also keep even more heat from working its way higher into the engine bay.
also, try running a true cold air intake if you arent already, and remove any restrictive grilles from the vehicle. I already did those mods even tho I don't have a header or turbo, i just want colder air :)
Old 03-13-2009, 12:22 PM   #4
Yoda
Yoda's Avatar
i feel like i lost some power gonna go to the mech after work and have them do a pressure test. I have the AFE intake i might need one that goes all the way down by the wheels cause even the intake felt a little hot at one point. That little metal shield is not holding up lol... But i love the sound of it. Any recommendations for a CAI? I am getting boarded with my car nothing else to do but FI...Well i do need some wheels And i need a catbak exhaust i dont kno where i can find one for my sedan:(
Old 03-14-2009, 08:10 PM   #5
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
A yaris pulling hard
Old 03-14-2009, 09:18 PM   #6
ddongbap
With a header leak, you'll gain top end power.
Old 03-14-2009, 09:36 PM   #7
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
you'll also throw off your o2 sensor, causing fueling issues, causing loss of power..
Originally Posted by xnamerxx
you nailed it sir.
Old 03-15-2009, 01:38 AM   #8
Yoda
Yoda's Avatar
as hard as its gonna. well there was no leak everything is good just the engine bay got hot and the intake was taking in all that hot air
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
Ping in Engine Bay... Kioshi DIY / Maintenance / Service 4 01-18-2009 03:26 PM
in cabin or in engine bay gwasabi Performance Modifications 4 01-10-2009 12:15 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
Engine bay prettification project eTiMaGo Cosmetic Modifications (Exterior/Interior) 14 04-23-2007 05:22 PM
