Old 03-13-2009, 02:13 AM   #1
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Coilovers - creaking sound from passenger front?
I had my Silk Roads installed awhile back and never really noticed it until now, but the front passenger emits a creaking sound, like that of an old wooden ship when I turn the wheel in either direction, lol.
It's a lot worse when I have a passenger with me. I have checked all the bolts to make sure nothing is loose and sorta eyeballed it, but I really have no clue what could be causing it.
Old 03-13-2009, 02:17 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
I had the same thing comming from my rear springs. Trick i used is use synthetic brake lube grease on the springs that are the most tightly wound. Now the sound went away.
Old 03-13-2009, 07:21 PM   #3
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
you installed the shims on the springs right?
preloaded to spec?
Russelt3hPirate is offline   Reply With Quote
Old 03-13-2009, 08:05 PM   #4
Crandall
H8R
Crandall's Avatar
Drives: 08 White RS
When you change your suspension geometry you're going to get some creaks and sounds. This is the case on every car I've worked on.
My coils squeak in the back from time to time, I don't even notice it anymore.
Old 03-13-2009, 08:57 PM   #5
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
The top rubber strut mount might be causing the creaking. Just need to lube it up with some grease but hardest part is getting to those strut mounts since getting to the bolts is a PITA. The rubber mount rubs up against the metal body every time you turn which causes a "creak" noise.
FunctionSpec is offline   Reply With Quote
Old 03-13-2009, 10:35 PM   #6
Gideon
★weeaboo★
Gideon's Avatar
preloaded to spec?
I didn't install them, this local tuner shop did.
Given he was unaware that the rear shocks were height adjustable, it's possible he didn't preload the springs to spec. Shims are on though, that much I know.
Old 03-15-2009, 03:52 PM   #7
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Omfg why would you let a shop work on your car ??? Its sounds like its just the coils creeking when they're getting compressed in turns .
Old 03-15-2009, 11:38 PM   #8
I have the Silk Roads on my car - absolutely no creaking sounds.
Old 03-15-2009, 11:39 PM   #9
ChinoCharles
Drives: LB
What kind of a question is that?
Old 03-16-2009, 12:06 AM   #10
blacksandiegovitz
Drives: 08 Vitz
I've just had really bad experiences with "tuner" and repair shops ef'n my car up , so now I just do all the work on my car . If I fuct something up at least it was my fault and didn't cost me 80+ dollars an hour for labor.
Old 03-16-2009, 12:13 AM   #11
Gideon
★weeaboo★
Gideon's Avatar
Yeah, I learned my lesson I think.
I didn't even pay for the installation to be honest though, and I still regret it, lol!
blacksandiegovitz - I had a friend who owed me money and his "boy" down at this tuner shop installed them for me as a favor for him to pay me back. I was impatient and lazy when I got them in and so I took him up on it.
Supposedly it was $150 worth of work according to the shop manager. (Friend owed me $90). It certainly didn't feel like I was getting that much of work out of them.
I'm probably going to check them out tomorrow to see what I can see down there. I need to jack up the car to take some detailed photos of how the calipers are attached for a hackjob OEM rotor/caliper rear conversion.
Old 03-16-2009, 12:55 AM   #12
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Mine doesn't squeek. Good luck!
Old 03-16-2009, 04:20 PM   #13
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
I've never been in a car with coil overs that didn't start to creak and squeak over time. do you notice the sound goes away when it's raining or on a humid day? I know Sacramento is kinda dry most of the year. do you have any camber up front?
aeipee13 is offline   Reply With Quote
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 01:25 PM
Creaking sound from the rear end after stops bumps, turns after it rained YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 03-06-2009 01:57 PM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 08:22 PM
Rattling in front passenger dash sr7628 DIY / Maintenance / Service 2 03-27-2007 01:24 PM
