Old 02-01-2009, 09:02 AM   #1
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Unhappy Help! I broke my engine!
After installing my NST underdrive pulley I was trying to move the alternator back into position to re-tension the belt when the rubber mallet I was using slipped and broke the connector off of this thing mounted to the block just above and to the right of the alternator! I took it out to take get a better look at it... Does any one know what this is? It looks like some sort of solenoid or valve with oil all over the end that goes in the block.I was able to straighten the tabs and push the broken piece back together but there were to tiny wires that I think were broken... The engine started after I put everything back together, but the check engine light came on... I hope what ever it is, it's not expensive, because I'm pretty sure it's not covered by warranty...
Old 02-01-2009, 09:06 AM   #2
I believe that is related to the VVT-i system, an activator of sorts.
Old 02-01-2009, 09:08 AM   #3
CtrlAltDefeat
I ♥ Yaris
any idea how much it costs?
Old 02-01-2009, 09:34 AM   #4
no idea, dude... tried to track down the part number but no luck
Old 02-01-2009, 10:50 AM   #5
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
oh boy, does the car still drive? maybe you can try disconnecting battery overnight, it could clear the engine light.
ur next car - no mods to engine/related until after warranty!
Yawesh is offline   Reply With Quote
Old 02-01-2009, 12:28 PM   #6
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
OUCH!
I know there are few mechanics on YW, try contacting YarisSedan, he may be able to help you out
Old 02-01-2009, 12:36 PM   #7
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i may have this part in my hand $80 shipped
Originally Posted by xnamerxx
you nailed it sir.
Old 02-01-2009, 12:39 PM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
either get Tamago's or I would salvage yard hunt
Old 02-01-2009, 01:13 PM   #9
CtrlAltDefeat
I ♥ Yaris
well it starts ok don't know if it will drive ok, if it does I'm going to go check what that check engine light means and look for a junkyard... I assume any 1NZ-FE will work out of a xA xB or other 1.5 yaris...
Old 02-01-2009, 01:14 PM   #10
CtrlAltDefeat
I ♥ Yaris
deal!
Old 02-01-2009, 01:26 PM   #11
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
looks like oil control valve assembly >>>>LINK<<<<
if that is the case.....I don't know if that is just the price for the screen on the end of that or what....I would hope it's for the whole piece...
if anything I'd print this diagram out and show whoever that location...
Old 02-01-2009, 01:43 PM   #12
jonismyname
Drives: 08 liftback 5spd
http://www.scribd.com/doc/8679168/20...12-Lubrication
paste lu-14
camshaft oil control valve.
sounds important.
im still looking for a part # for ya
jonismyname is offline   Reply With Quote
Old 02-01-2009, 01:45 PM   #13
jonismyname
http://www.scribd.com/doc/8677989/20...Specifications
page 4 gives you resistance specs. maybe some solder and a small iron can get you running again, and you would be able to check it. maybe a temp or if part is pricey...
Old 02-01-2009, 01:48 PM   #14
jonismyname
http://www.pressroom.com.au/pressroo...ts/echokit.htm
cut and pasted interesting bit below
Toyota Echo’s VVT-i is a computer controlled and oil-pressure activated push- push type system.
The engine ECU can command the system to advance or retard the inlet camshaft timing, thereby providing for faster response.
The hardware is a camshaft timing oil control valve mounted adjacent to the inlet camshaft gear wheel and a VVT-i controller mechanism built onto the inlet camshaft timing gear.
The camshaft timing oil control valve is a spool valve, controlled via a coil and plunger by the engine ECU.
It can signal "advance", "hold" or "retard". The VVT-i controller consists of a housing on the front of the timing wheel, driven from the timing chain, and a four-bladed vane coupled with the intake camshaft.
When the engine ECU requires a change in inlet timing, it signals the oil control valve to provide oil pressure to either the advance or retard side of the four vane chambers.
A locking pin in the controller locks the camshaft timing in the maximum retard position for engine start-up and immediately after start-up (until oil pressure is established) to prevent any knocking noise.
Old 02-01-2009, 02:25 PM   #15
YarisSedan
Drives: 08 Yaris Sedan
Looks like some sort of cam sensor. I would say its very important.
Old 02-01-2009, 03:13 PM   #16
CtrlAltDefeat
I ♥ Yaris
It is the camshaft timing oil control valve assembly. part# 11101J According to toyodiy.com it's $103.72 But I think I can get it from a local salvage yard for a lot cheaper... any ways now I know what it is and where I can get i... Thank you so much for your help, you have no idea how much I appreciate it!
Old 02-01-2009, 03:17 PM   #17
Tamago
Tamago's Avatar
Drives: ZZW30
not a bad price
i'll do it for $50 shipped.. save you the trouble of hunting at the salvage yard?
you nailed it sir.
Old 02-01-2009, 03:23 PM   #18
Tamago
Tamago's Avatar
Drives: ZZW30
you nailed it sir.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
FS: Used Beatrush Engine Roll Stopper FunctionSpec Items for Sale by private party 7 06-02-2010 02:38 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 01:51 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 10:02 AM
