![]() Drives: Yaris Hatchback Join Date: Aug 2006
Coolant Light
I've had my liftback automatic for a week now, and when I went out in it today I noticed my coolant light stayed on for what seemed like a long time after all the other warning lights went off. The light did go off, but I am a tad bit worried. Of course it's a long weekend and the dealers service department was closed, do you think it's safe to drive until I can have it checked out on Tuesday?
Thanks, Cathy |
![]() Drives: 2007 Yaris Liftback Join Date: Aug 2006
It's a light that lets you know the engine (or coolant) is still cool.. I can't remember if the manual said to let it go off before you started driving or not. I hope it's okay, After I start up my car it stays on until I get to almost the first stop sign leaving my neighborhood. :)
Look in your manual for the dash indicator lights.. it will describe what it is for sure. Don't trust me, I'm crazy! haha! |
Aunty Yaris is In!
Drives: Blazing Blue, 2 Dr Hatchback Join Date: Aug 2006
Mine, does the same thing, and I was worried too. I just means that the engine is still cool, even if your sitting in an heated underground parkade like I am. It eventually goes aways like jsurles said by the time you get driving after a few minutes. The only time I don't see it come on is when my car is outside baking in the hot sun all day. According to the owners manual this is normal behaviour unless it stays on constantly. I've had my car for 2 weeks now.
Thanks for the responses, I appreciate them. The car was last driven friday night and about noon I went out and noticed the light, and it was probably close to 100 degrees.
Cathy |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
The cool light will stay on until the engine has reached normal operating temps. you can dive it with the cool light on but drive it easy. the light should go off within a couple miles/minutes
It's normal.At my Yaris, the light remained green for 2 minutes and it was 43C οutside!
There has been a thread on this topic... It is normal
http://www.yarisworld.com/forums/showthread.php?t=1579 If this dont work the thread is called "reluctant upshift to 3rd while cold". |
Wait until the dead of winter when the thing stays on forever.
Never plan on taking off in a hurry in the winter after the car has been sitting all night. Seems like you'll never hit 4th gear and you'll be afraid your going to blow up your engine. Had an Echo a few years back and hated that. Didn't realize the Yaris was going to be that way too. Hmm. . . . . Wonder if there is a way to disable that????
#9 | |
HardlyDangerous
#10 | |
#11 | |
![]() ![]() ![]() Drives: Scion FRS Join Date: Aug 2006
If your winters are that cold get a block heater.. -.- And flaming 07WYarisRS was probably the 2nd dumbest thing to do since he's actually trying to help explain to you WHY that light is there. |
![]() ![]() ![]() Drives: 2k3 Cavalier & 2k2 Echo Join Date: Aug 2006
Same thing here on the Echo... the light remain ON until the engine get warm. :)
2003 Chevy Cavalier Ecotec - His car! 2002 Toyota Echo Sedan - Her car... FOR SALE! |
Small Car Lover
I remember not long after I got my ECHO I saw the blue light and I thought something was wrong. So I called the dealers service dept and told him about it and he's like its just the temp light letting you know the car is still cold. Boy did I feel like and idiot!
But it was or is my first car with idiot lights (no pun intended), my previous car had a guage which I perfer but oh well! The reason it doesn't upshift to the overdrive gears (4th) is to bring up the engine to "normal" operating temps faster also its emission reasons (from what I read).
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
#14 |
HardlyDangerous
It was a smart ass remark because it's a silly question
Why would you want to disable somthing that saves your emissions control system, saves fuel and helps protect the engine and transmission from damage? If you can't stand the car holding the shift a slightly longer warm up is a solution to the problem. |
#15 |
07WYarisRS
#16 |
HardlyDangerous
Maybe you could try to act a little more mature.
It's not very often we get to see someone get their panties all in a bunch and carry on like you do... that the type of response I would expect from my 11 year old niece not a mature car owner. If you knew ANYTHING about an automatic transmission you would know how to disable it but then you would know that after doing so it won't shift properly when warm either and will shorten the life of the gears and clutches. GENIUS If you want to get around it you have to warm it up longer… Maybe it's just good common sense on the part of the other owner/operators here not to rev the living shit out of a cold engine/trans to the point they fear they are going to blow the engine because it's not yet up to normal operating temps and holding the shift. Most cars will hold top gear, overdrive or TCL until they reach operating temps. Both engines and trans are temp sensor controlled and disabling the sensors will send false signals to the ECU's and the car can't adjust timing, fuel trims or shift points accordingly because it had no way of knowing if they are up to safe operating temps or not and will run in fail safe/open loop modes. Bang goes your reliability, warranty and longitivity of these components. Last edited by 07WYarisRS; 09-03-2006 at 11:37 PM. |
| MAINT REQD light | PSU Yaris | DIY / Maintenance / Service | 9 | 12-24-2008 05:48 PM |
| yaris digital speedo light up? | jamal1984 | General Yaris / Vitz Discussion | 7 | 08-27-2006 03:01 AM |
| Interior Light Kit... for Canadian version?! | Jem_hadar | Cosmetic Modifications (Exterior/Interior) | 5 | 08-17-2006 02:20 AM |
| Removing third brake light | lightyearsgirl | DIY / Maintenance / Service | 8 | 08-06-2006 11:26 AM |
| light covers | KSIbucky | Cosmetic Modifications (Exterior/Interior) | 7 | 06-07-2006 05:08 AM |
