Old 12-26-2008, 06:08 AM   #1
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Which lowering springs should I choose?
Hi
I have a Toyota Yaris 1,3 5dr. Hatchback from 2007, the European model.
I would like to get it lowered, but only by springs.
Which set does the job well and is a good quality so the springs doesnīt break when driving in the cold weather in Denmark with salt on the roads.
I have looked at some Tanabe springs, but whatīs the difference on DF210 and NF210 and is Tanabe a quality brand, never heard of it in Denmark.
The DF210 should lower by 1,6 front and 1,8 rear, but why does it lower more in the rear, usually I think it should be lowered more in the front?
Also looked at Tein that is a little more expensive and it should lower by 1,9 inches front and rear.
Anybody have experiences with these sets or others and do they lower the car as much as promised?
Then I have looked at the original Toyota TTE springs, but they doesnīt lower it much, www.tte.de .
Regards Steven.
Danish Yaris is offline   Reply With Quote
Old 12-26-2008, 08:53 AM   #2
tanabe seems to be a decent japanese brand....i wouldnt worry about them
and youre not THAT cold in denmark....hovering around 0C....but i could see the salt being a pain if they use a lot.....but no aftermarket spring would rust thru any quicker than OEM springs....
what size of drop do you want? big drop or not big drop?
Old 12-26-2008, 09:04 AM   #3
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Like the Barber said, it depends on the desired drop. I had Tein S-Tech lows on my car for about 8 months, really liked the stance and feel they gave my car but they rubbed too much for my liking. More recently I swapped the Teins for a set of Tanabe NF210's and I like them much better...they seem to give the car a bit of a stiffer ride and there is virtually no rubbing even under hard cornering.
Unless you are willing to invest in coil-overs, I would put my money to use on a set of Tanabe's. If you would like a "dramatic" drop, get the DF210's, if you would like a mild drop and a great ride, buy the NF210's. Garm is selling them both at great prices...
www.microimageonline.com
Wanted: Forced Induction
Old 12-26-2008, 12:01 PM   #4
Danish Yaris
Hi
I want a drop at about 4cm., it must be about 1,6 to 1,8 inches.
Itīs not that cold in Denmark, but itīs just above 0*C now and they like to use very much salt on the roads.
I have just heard about some that has broke their H&R springs.
What do you use?
Regards Steven.
Old 12-26-2008, 12:02 PM   #5
^ thanks for posting that info.
on the product pages it gives spring rates and drops. The DF210's are closer to 1.8-2" from customer reviews.
I might also mention the killer deal we have on Progress springs right now -- they are between the DF and NF Tanabe springs in drop, and only $144.95 right now (until I run out).
Old 12-26-2008, 12:05 PM   #6
Danish Yaris
Hi
I want about 1,6 to 1,8 inches drop.
What do you mean with it rubbed too much? Do the wheels rub onto the wheel wells or fenders?
How much did the Tein S-Tech lower your car?
You say I should choose the DF210 for a dramatic drop and the NF210 for a great ride? What do you mean by that? Does it get bad handling with the DF210īs?
I would like the car to be stiff and good in the curves?
Who is Garm?
Regards Steven.
Old 12-26-2008, 12:10 PM   #7
Danish Yaris
Hi
I have sent you a PM.
Regards Steven.
Old 12-26-2008, 01:41 PM   #8
cali yaris = garm
sounds like progress springs might do the trick if the shipping isnt too much...
Old 12-27-2008, 01:22 PM   #9
Danish Yaris
Hi
I have sent Garm a PM.
Regards Steven.
Old 12-27-2008, 08:09 PM   #10
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
Originally Posted by Danish Yaris View Post
Hi
Regards Steven.
Steven, I think TRD have an outlet in sweden, they did when I lived there at least. Should be cheaper to order from there.
ZING is offline   Reply With Quote
Old 12-27-2008, 08:12 PM   #11
ChinoCharles
Drives: LB
DF's FTW. I think those and the S Tech's have the best stance, since they're very similar. One of my few regrets on my car is that I am on TRD springs and not DF's, but that is what coilovers are for.
Old 12-27-2008, 08:17 PM   #12
ZING
ZING's Avatar
Might take that offer of DF's..
Old 12-28-2008, 04:37 AM   #13
Danish Yaris
Hi
I think I will buy the DF210´s, but am a little cocerned about if the front tires will rub against the plastic on the fenders.
Regards Steven.
Old 12-28-2008, 06:52 AM   #14
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Hi
Who is Garm?
Regards Steven.
Steven,
The rubbing was between the tire and the wheel well, not the fenders.
The Tein S-Tech springs lowered my car approximately 1.9" at each corner.
I apologize for my choice of words regarding the choice between the NF and the DF; what I mean is that the NF springs have provided me with a better feel than the Teins with a nice looking drop but the car does not sit as low as it would with the DF springs. You won't really get a stiff ride by just swapping out the springs, you may have to upgrade your shocks/struts and purchase other suspension add-ons.
-Matt
Old 12-28-2008, 04:26 PM   #15
Danish Yaris
Steven,
-Matt
Hi Matt
Ok, but it must me more stiff than it is stock when itīs lowered about 1,6"-1,8"?
Which wheels did you have on when it rubbed the wheel wells and can there be done anything to it? Was it every time you drove?
Regards Steven.
Old 12-28-2008, 05:53 PM   #16
NF210 is about 5% over stock in stiffness, DF210 is 10-15%.
Old 12-28-2008, 06:02 PM   #17
ZING
ZING's Avatar
Is anything else necessary besides the springs, such as coils?
Old 12-28-2008, 08:33 PM   #18
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
You can put new struts/shocks on but if you just want to drop it with springs, feel free.
I have DF210 springs on mine with the stock shocks and 37,000 miles, no problems.
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Which lowering springs? Danish Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-25-2008 12:18 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
