Old 07-21-2011, 12:48 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Transmission oil cooler on MT?
I just finished tearing apart an defunct window air conditioning unit, and the interior radiator was still in pretty good shape. The little mod monkey in my head said "Hey, you should put that on your car!" but I wasn't sure if it would be of any use.
I know on 4WD vehicles there is a separate cooler for the transfer case, and that the AT Yaris has an oil cooler for the transmission. Is there any point in adding a radiator to a manual transmission?
Old 07-21-2011, 01:05 PM   #2
djct_watt
Drives: 2010 NCP91 5spd
Not really, unless you grind your gears on purpose or neglect to change your transmission oil. IMO, your money would be better spent on changing your MT oil more often. 4WD is a different story.
The best modification you can make is between the steering wheel and driver's seat.
Old 07-21-2011, 01:44 PM   #3
Jason@SportsCar
No. You can't work it hard enough to hurt it with little bit of power the Yaris produces.
Old 07-21-2011, 01:52 PM   #4
bronsin
bronsin's Avatar
A manual transmission HEATER might be good for winter!
Old 07-21-2011, 01:56 PM   #5
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
On the MT all the extra heat sink is required.
There's no oil is heated to as AT.
MickZEL is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Transmission Oil for Yaris 1st Gen adigilani DIY / Maintenance / Service 3 10-23-2011 03:48 PM
